Choose paraview version by environment variable |
January 15, 2010, 03:52 |
BastiL
Rep Power: 20 |
Dear all,
I use the pvFoam script to launch Paraview and the external parallel reader. This works find and has the advantage of being independent from OpenFOAM. I want to update to Paraview 3.6.2 and there is no need to recompile paraFoam or anything else from the OF package. Now I want the user to have the choice of which pv to be used. This can be done by setting ParaView_VERSION. However, etc/apps/paraview3/bashrc overwrites this setting: Code:
export ParaView_VERSION=3.6.1 Code:
: ${ParaView_VERSION:="3.6.1"}; export ParaView_VERSION Regards BastiL |
January 21, 2010, 00:16 |
Jie
Rep Power: 16 |
Hi Bastil
OpenFOAM comes with paraview 3.6.1 and I have downloaded the new paraview 3.6.2. I have tried to modify the etc/apps/paraview3/bashrc with your suggestion and it still opens up with paraview 3.6.1 when I use "paraFoam" Could you please explain a bit more about how to integrate the new paraview 3.6.2 with OpenFOAM 1.6? Thanks a lot. |
January 27, 2010, 10:21 |
Mattijs Janssens
Rep Power: 26 |
Thanks for the change. I've pushed something similar to 1.6.x. You now have
ParaView_MAJOR ParaView_VERSION which default to paraview-3.6 and 3.6.1. |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Setting working environment variable | Arthur | FLUENT | 0 | December 10, 2008 04:33 |
hi how to set entironment variable in CFX pre | romance | CFX | 0 | December 23, 2007 07:11 |
Environment variable MPI_GROUP_MAX | Satya | Siemens | 0 | May 29, 2007 02:16 |
environment variables version 3.2 | F.K. | Siemens | 15 | June 28, 2004 12:41 |
