On compiling - CompactListListI.H (expected type-specifier before ‘>’)
I'm trying to compile 1.6.x, but I get an error:
/home/kjetil/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/CompactListListI.H:74: error: expected type-specifier before ‘>’ token.. and I get a make error. Performing a text search in the lnInclude-dir reveals that this is the only file that doesn't have a type-specifier. Is this on purpose? I'm using system compiler on Ubuntu 9.10 64bit. |
As there are several other "*ListI.H" in that directory, I compared the content, and made a change in the CompactListListI.H:
CompactListList<T>* nullPtr = reinterpret_cast< >(0);to CompactListList<T>* nullPtr = reinterpret_cast<CompactListList<T>*>(NULL);The ./Allwmake is currently running, but has so far not experienced the same errors as before. |
Done. Seemed to work. Also, had to disable (<- remove) tecplot360 directory, as it was nagging about files that could not be found. True, as they (i.e TECIO.H) are now placed in a subfolder.
Thanks. 1.6.x should now build cleanly (on linux64 at least) , including foamToTecplot360.
The only problem when making the PV3FoamReader, is when using 'system' compiler, it looks for '/bin/c++', not '/usr/bin/c++'. If I change to compiler in settings.sh to 'OpenFOAM', it works. Should I add a symbolic link in '/bin/ to fix this?
Bit complex. Since cmake produces non-relocatable cmake files the buildParaview script replaces some hardcoded paths with environment variables, one of which is WM_COMPILER_DIR
workaround 1: change in the paraview build directory, in platforms/linux64Gcc/Common/KWCommon/KWCommonBuildSettings.cmake the setting for CMAKE_BUILD_SETTING_C_COMPILER CMAKE_BUILD_SETTING_CXX_COMPILER workaround 2: make a directory structure with a bin/c++ and bin/c in it (can be softlinks to your real compiler) and set WM_COMPILER_DIR to it. |
