November 11, 2012, 18:28 |
Is e actually the Enthalpy in rhoCentralFoam?
Ruben Moreno
Rep Power: 14 |
Dear all,
I have been struggling for some time comparing the equations and the flux calculations in Openfoam, but I guess I know more or less now what it is all about. However, checking the relationship between psi and the energy I have found a discrepancy that I would like to confirm if it is real or not. I am using OpenFoam 2.1, the ShockTube tutorial. If I output directly to a file e and T, it happens that e is not Cv*T, as one would expect, but Cp*T (i.e. the Enthalpy). However, the Energy equation, at least to my knowledge, is treating e as the energy and adding the pressure to it. Am I missing something or this is an actual bug? Thanks a lot and best regards Last edited by rmoreno; November 11, 2012 at 21:57. |
November 18, 2012, 17:34 |
Ruben Moreno
Rep Power: 14 |
It turns out that this is an already known bug (see http://www.openfoam.org/mantisbt/view.php?id=571#c1445).
In fact it only returns the enthalpy when T=Tstd, which was the case. Anyway, it was its inconsistency with the standard perfect gas formulation what was giving me headaches. Regards! |
energy, enthalpy, rhocentralfoam |
Sensible Enthalpy vs. Total enthalpy | Sethi | OpenFOAM Programming & Development | 3 | March 23, 2017 21:48 |
Defining Inlet Mixture Enthalpy | Munggang | FLUENT | 0 | March 2, 2012 16:50 |
Mismatch between H-Energy and massFlowInt(Static Enthalpy) | Chander | CFX | 13 | December 16, 2011 11:37 |
derivation enthalpy | Tomik | FLUENT | 2 | March 9, 2006 15:39 |
meaning static enthalpy and total enthalpy | mspark | Siemens | 1 | April 1, 2004 06:20 |
