Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Wrong calculation of yPlus for low-Re models
Old   February 5, 2010, 03:25
Default Wrong calculation of yPlus for low-Re models
BastiL
bastil is on a distinguished road
According to this thread:
http://www.cfd-online.com/Forums/ope...us-values.html
yPlusRAS calculates wrong values for low-Re turbulence models. Could someone check that, please? Thank you.
bastil is offline   Reply With Quote
Old   February 8, 2010, 06:12
henry is on a distinguished road
Currently the low-Re turbulence models do not use the new nut/mut boundary condition method for specifying the wall-modeling and are hence out-of-date with respect to the yPlusRAS utility. We will update the nut/mut boundary conditions for these models for the next release. In the meantime it is possible to calculate the yPlus for these models using the method in previous versions of OpenFOAM.
H
henry is offline   Reply With Quote
Old   February 8, 2010, 07:44
BastiL
Thanks Henry. How can this be done? Using yplusRAS from 1.5.x? Will this be the proposed way and give correct results? Thanks.
Old   February 9, 2010, 07:09
We have retrofitted developments from the next release back into OpenFOAM-1.6.x to support the calculation of yPlus for low-Re turbulence models.
See the boundaryLaunderSharma tutorial in which the appropriate BCs for nut are specified which supports the calculation of yPlus using the yPlusRAS utility.
H
Old   February 9, 2010, 07:39
BastiL
Great, thanks.
udf error srihari FLUENT 1 October 31, 2016 14:18
Multiphase flow calculation chiven OpenFOAM Running, Solving & CFD 3 January 14, 2011 04:27
yplus value in two phase flow P.R.Naren FLUENT 0 September 5, 2006 02:10
Multiphase flow application and models Jonathan Main CFD Forum 1 August 17, 2006 10:45
Warning 097- AB Siemens 6 November 15, 2004 04:41
