Dimesion error after switching from simpleFoam to rhoSimpleFoam |
June 17, 2010, 07:06 |
Dimension error after switching from simpleFoam to rhoSimpleFoam
Sebastian Saegeler
Rep Power: 16 |
Hi everybody,
I got an dimension error after switching from simpleFoam to rhoSimpleFoam. I created a starting solution with simpleFoam and everything worked fine. Now I have reached steady state and I want to switch to rhoSimpleFoam to solve for the compressible case. Unfortunateley I received an error... // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 25 Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon --> Upgrading k to employ run-time selectable wall functions Backup original k to k.old Writing updated k --> Upgrading epsilon to employ run-time selectable wall functions Backup original epsilon to epsilon.old Writing updated epsilon --> Creating mut to employ run-time selectable wall functions Writing new mut --> Creating alphat to employ run-time selectable wall functions Writing new alphat [1] [1] [1] Different dimensions for = dimensions : [1 -1 -1 0 0 0 0] = [0 2 -1 0 0 0 0] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>:perator=(Foam::tmp<Foam::Geometri cField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoSimpleFoam" #4 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleRASModels.so" #5 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleRASModels.so" #6 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libcompressibleRASModels.so" #7 main in "/home/sebastian/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoSimpleFoam" #8 __libc_start_main in "/lib/tls/libc.so.6" #9 _start at ../sysdeps/i386/elf/start.S:122 [1] [1] [1] [1] [1] From function dimensionSet:perator=(const dimensionSet& ds) const [1] in file dimensionSet/dimensionSet.C at line 143. [1] FOAM parallel run aborting Anybody an idea?? Best regards, Sebastian Last edited by sebastian; June 17, 2010 at 07:26. |
June 17, 2010, 07:24 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Sebastian
In simpleFoam the pressure is normalized with density, i.e. you need not to specify it, however in rhoSimpleFoam the density varies, hence you should modify 1. Dimensions in your pressure file 2. The magnitude of the pressure, i.e. multiply by rho. Best regards, Niels |
June 17, 2010, 08:03 |
Sebastian Saegeler
Rep Power: 16 |
Hi Niels!
Thanks a lot! Now it works! Sebastian |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
