Home > Forums > OpenFOAM Bugs
Possible bug (limitation?) in setValues
Old   March 25, 2010, 14:37
Default Possible bug (limitation?) in setValues
Alberto Passalacqua
in trying to use setValues to exclude cells were the momentum equation is not defined (rho ~ 0) from the matrix, I found a potential bug/limitation (if I didn't do anything wrong in my code ).
Let's assume the momentum equation is in the compressible form, and I want to exclude cells were rho < SMALL. I loop to identify those cells:
labelHashSet doNotSolveMomentum;
forAll(rho, cellI)
  if (rho[cellI] <= 1.0e-6)
    doNotSolveMomentum.insert(cellI);
Then I create the list of cell labels and the field of values I want to fix:
labelList noMomentumCellLabels = doNotSolveMomentum.toc();
vectorField fixedU (noMomentumCellLabels.size());
forAll(fixedU, cellI)
  fixedU[cellI] = vector(0.0, 0.0, 0.0);
UEqn.setValues(noMomentumCellLabels, fixedU);
Now, when I check the central coefficient, it is zero in the cells where the condition is satisfied with the code:
myA = UEqn.A();
forAll(rho,i)
  if (rho[i] < 1.0e-6)
    Info << "rho = " << rho[i] << " A = " << myA[i] << endl;
I obtain a list of zeros for A, which causes a division by zero when computing U = H/A.
Is this the expected behaviour of setValues? Shouldn't A be set to 1 in those cells, so that the equation actually degenerates in U = myValue?
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   March 26, 2010, 04:16
henry is on a distinguished road
setValues currently does not reset the diagonal, it uses the value the matrix provides to set the value.
H
henry is offline   Reply With Quote
Old   March 26, 2010, 05:29
Hrvoje Jasak
Hi Alberto,
You cannot just go in and change the diagonal value to 1 because the order of magnitude of other terms in the matrix is unknown: other diagonals can be anything betwees, say 1e-10 and 1e10, depending what you're solving.
If you give the diagonal of a wrong order of magnitude, it will change matrix normalization and that makes the solver behave in unexpected ways. I had this trouble with the FEM solvers a long time ago and the solution was to leave the diagonal as is.
How come you have a zero diagonal in the first place? Can you estimate the size of the diagonal coefficient, eg. cell volume/delta t?
Hope this helps,
Hrv
Hrvoje Jasak
Old   March 26, 2010, 12:04
Alberto Passalacqua
Thanks to both of you for your replies.
The diagonal is zero because in those cells the equation is undefined (0 = 0), due to rho being zero (or very small).
At the moment I am using a flag to set up the fvMatrix, doing something like
fvVectorMatrix UEqn
   solveMomentum*
          fvm::ddt(...).
   doNotSolveMomentum*
       fvm::Sp(Uunits,U)
but I was looking for a cleaner and possibly less intrusive solution.
Best,
Alberto Passalacqua
Old   March 26, 2010, 20:45
Alberto Passalacqua
I forgot to answer to one point: in my case both the cell volume and the time step are usually constant (static mesh, fixed dt), so their ratio is known.
Best,
Alberto Passalacqua
Thread Tools
Trackbacks are On
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 09:15
surfaceToPatch bug? bruce OpenFOAM Bugs 4 November 12, 2009 09:23
Please report this bug egp OpenFOAM Installation 5 December 8, 2006 13:56
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 11:22
