March 25, 2010, 13:37 |
Possible bug (limitation?) in setValues
Alberto Passalacqua
Rep Power: 36 |
in trying to use setValues to exclude cells were the momentum equation is not defined (rho ~ 0) from the matrix, I found a potential bug/limitation (if I didn't do anything wrong in my code ). Let's assume the momentum equation is in the compressible form, and I want to exclude cells were rho < SMALL. I loop to identify those cells: Code:
labelHashSet doNotSolveMomentum; forAll(rho, cellI) { if (rho[cellI] <= 1.0e-6) { doNotSolveMomentum.insert(cellI); } } Code:
labelList noMomentumCellLabels = doNotSolveMomentum.toc(); vectorField fixedU (noMomentumCellLabels.size()); forAll(fixedU, cellI) { fixedU[cellI] = vector(0.0, 0.0, 0.0); } UEqn.setValues(noMomentumCellLabels, fixedU); Code:
myA = UEqn.A(); forAll(rho,i) { if (rho[i] < 1.0e-6) { Info << "rho = " << rho[i] << " A = " << myA[i] << endl; } } Is this the expected behaviour of setValues? Shouldn't A be set to 1 in those cells, so that the equation actually degenerates in U = myValue? Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
March 26, 2010, 03:16 |
Rep Power: 22 |
setValues currently does not reset the diagonal, it uses the value the matrix provides to set the value.
H |
March 26, 2010, 04:29 |
Hrvoje Jasak
Rep Power: 33 |
Hi Alberto,
You cannot just go in and change the diagonal value to 1 because the order of magnitude of other terms in the matrix is unknown: other diagonals can be anything betwees, say 1e-10 and 1e10, depending what you're solving. If you give the diagonal of a wrong order of magnitude, it will change matrix normalization and that makes the solver behave in unexpected ways. I had this trouble with the FEM solvers a long time ago and the solution was to leave the diagonal as is. How come you have a zero diagonal in the first place? Can you estimate the size of the diagonal coefficient, eg. cell volume/delta t? Hope this helps, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 26, 2010, 11:04 |
#4 | |
Alberto Passalacqua
Rep Power: 36 |
Thanks to both of you for your replies.
At the moment I am using a flag to set up the fvMatrix, doing something like Code:
fvVectorMatrix UEqn ( solveMomentum* ( fvm::ddt(...). + ... ) + doNotSolveMomentum* ( fvm::Sp(Uunits,U) ) ) Best,
March 26, 2010, 19:45 |
Alberto Passalacqua
Rep Power: 36 |
I forgot to answer to one point: in my case both the cell volume and the time step are usually constant (static mesh, fixed dt), so their ratio is known.
Best,
Serious bug in LES interface | fs82 | OpenFOAM Bugs | 21 | November 16, 2009 08:15 |
surfaceToPatch bug? | bruce | OpenFOAM Bugs | 4 | November 12, 2009 08:23 |
Please report this bug | egp | OpenFOAM Installation | 5 | December 8, 2006 12:56 |
Bug reports | Mattijs Janssens (Mattijs) | OpenFOAM | 0 | January 10, 2005 10:05 |
Forum y2k Bug | Jonas Larsson | Main CFD Forum | 1 | January 5, 2000 10:22 |
