Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
directMappedPatch and Badly formed bounding box
Like Tree1Likes
  • 1 Post By mattijs
Old   March 31, 2010, 14:24
Default directMappedPatch and Badly formed bounding box
Marco
om3ro is on a distinguished road
Everything works perfectly in this simpleFoam case of a 2D channel, with the directMappedPatch utility used to achieve the fully developed flow.
But absurdly, when I change ONLY the data in red:
blocks
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
I obtain this error:
Badly formed bounding box0.5 0.25625 0.05) (0.621875 0.378125 0.05)#0 Foam::error:rintStack(Foam::Ostream&) in "/home/om3ro/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/om3ro/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"...etc...
I append the compressed files.
Please use the following commands:
blockMesh -> changeDictionary -> simpleFoam
Since you use (20 20 1) in blockMeshDict no error occurs, but try to use (40 40 1) or other combinations and you get the error.
Thanks
Marco
om3ro is offline   Reply With Quote
Old   April 1, 2010, 04:16
Mattijs Janssens
mattijs is on a distinguished road
In 1.6 it does not like having the directMapped on a coordinate plane. This has been fixed in 1.6.x. Alternatively very slightly perturb your geometry so the patch you are mapping from is not on a plane.
Thanks for reporting,
Mattijs
wht likes this.
mattijs is offline   Reply With Quote
Old   April 1, 2010, 06:01
Marco
it works now, thanks!
marco
badly formed bounding box, directmappedpatch
