OF 1.6.x pulled at 03/05/2009 compilation error |
May 4, 2010, 10:28 |
Hi Foamers,
I've just pulled the 1.6.x release, but when I do Allwmake it gives me some errors: In file included from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvm.H:44, from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvCFD.H:10, from wallGradU.C:33: /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:41:31: error: geometricOneField.H: No such file or directory In file included from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvm.H:44, from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvCFD.H:10, from wallGradU.C:33: /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:63: error: expected ',' or '...' before '&' token /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:65: error: ISO C++ forbids declaration of 'geometricOneField' with no type In file included from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.H:90, from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvm.H:44, from /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvCFD.H:10, from wallGradU.C:33: /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C:63: error: expected ',' or '...' before '&' token /opt/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvmDdt.C:65: error: ISO C++ forbids declaration of 'geometricOneField' with no type It repeats many times this error with geometricOneField.H. It's a bug or it depends on something on my machine? Thanks, Ivan |
May 6, 2010, 01:24 |
#2 | |
Mark Olesen
Rep Power: 40 |
Try the following: Code:
cd $WM_PROJECT_DIR wmakeLnIncludeAll src applications # use wmakeLnIncludeAll -help to see what the command does |
May 6, 2010, 03:38 |
Hi to everybody,
this morning I tried with the suggestions of Olesen, in particular I did rmdepold and wmakeLnIncludeAll before Allwmake, but now new errors: make: *** No rule to make target `lnInclude/makeParcelIOList.H', needed by `parcels/derived/BasicReactingMultiphaseParcel/defineBasicReactingMultiphaseParcel.dep'. Stop. and + wmake libso coalCombustion make: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-1.6.x/src/lagrangian/intermediate/lnInclude/makeParcelIOList.H', needed by `CoalParcel/defineCoalParcel.dep'. Stop. It seems to complains on something in lagrangian models and combustion. As a result, obviously it do not build the related applications. Some suggestions? Thanks, Ivan |
May 6, 2010, 04:42 |
#4 | |
Mark Olesen
Rep Power: 40 |
For example, Code:
rmdepall makeParcelIOList.H |
May 6, 2010, 10:00 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
