Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Stuff that is missing in OpenFOAM 1.7 released today...
Old   June 26, 2010, 14:34
Default Stuff that is missing in OpenFOAM 1.7 released today...
Retired Super Moderator
Bruno Santos
Dear OpenCFD developers,
I think it's the 3rd year in a row that you've left out the Make files for libccmio in the ThirdParty folder
In other words, the folder "ThirdParty-1.7/wmakeFiles/libccmio", with the files "files" and "options", is missing (again)
Best regards,
Bruno
PS: Sweet work with the release of the Debian packaging! That will make life easier for a lot of beginners Many thanks!!
NOTE: This note is just because some user might report aimlessly about this issue in a near future, although it's not a critical error at all:
foamInstallationTest doesn't give an OK report with the debian package, because "/opt/ThirdParty-1.7" folder doesn't exist. Additionally, since the system gcc is picked, it looks for it in the folder "/bin/gcc", when in Ubuntu it's "/usr/bin/gcc".
Old   June 27, 2010, 11:36
henry is on a distinguished road
I have repacked the ThirdParty-1.7.tgz with the Make file for libccmio.
The foamInstallationTest script is for the source-build installation as described in the README.org file, not for the Debian pack installation.
H
henry is offline   Reply With Quote
Old   July 12, 2010, 18:24
Bruno Santos
Greetings Henry,
I'm sorry for pulling this thread back up, but it seemed more appropriate to post here, rather then starting a new thread. Oh and thanks again for the quick repackaging!
This post is to report that AllwmakeLibccmio will not work with the general shell sh (more specifically, Ubuntu's dash). But it worked with bash, similarly to what use to happen with the All* tutorial scripts.
The only fail point with sh was in the function cpMakeFiles, that although it did create the folder Make inside libccmio-2.6.1, but it did not manage to copy the existing files in the folder wmakeFiles/libccmio
My apologies for not finding+reporting this sooner and sadly I can't figure out why it doesn't work with dash either
Best regards,
Bruno
Old   July 13, 2010, 05:48
There seems to be a difference of opinion between bash and ash/dash concerning the outcome of the "newer than" conditional "-nt" when one of the files does not exits. To avoid this we can add an explicit test for the existence of the files before using "-nt".
So in cpMakeFiles use the condition:
if [ ! -e $dst/$d/Make/$b -o $wmakeFiles/$i -nt $dst/$d/Make/$b ]
which seems to work fine with dash.
H
Old   July 14, 2010, 02:55
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
According to the bash man page
file1 -nt file2
True if file1 is newer (according to modification date) than file2, or if file1 exists and file2 does not.
This is consistent with how /usr/bin/test behaves too.
olesen is offline   Reply With Quote
Old   July 14, 2010, 05:47
Bruno Santos
Greetings to all,
Henry: thank you for the quick response. It works very well with dash Too bad this wont get to be repackaged in 1.7.0
Olesen: But sadly dash doesn't think the same:
Originally Posted by http://linux.die.net/man/1/dash
file1 -nt file2
True if file1 exists and is newer than file2.
And if you search for test in FreeBSD's man, you'll get the same interpretation of -nt
Don't forget that bash stands for Bourne-Again SHell
Best regards,
Bruno
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 18:22
OpenFOAM Version 1.4.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 3, 2007 07:31
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 18:06
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 05:33
