directMapped problem
I used the "directMapped" to recycle the velocity back.
This has 3 sampleMode : nearestCell , nearestFace , nearestPatchFace. in his example , tutorials/incompressible/pisoFoam/les/pitzDailyDirectMapped, nearestCell method works fine. This is the boundary file for nearestCell. 5 ( inlet { type directMappedPatch; nFaces 30; startFace 27238; sampleMode nearestCell; sampleRegion region0; samplePatch none; offset (0.0495 0 0); } outlet { type patch; nFaces 57; startFace 27268; } upperWall { type wall; nFaces 275; startFace 27325; } lowerWall { type wall; nFaces 302; startFace 27600; } frontAndBack { type empty; nFaces 27570; startFace 27902; } ) but nearestFace method doesn't work well. In the begining, it doesn't work. Then I changed the startFace to 0, it works, but it doesn't works well, several steps later, it crashed. Who have used this sampleMode, can give some suggestions ? The following is my boundary file for nearestFace. 5 ( inlet { type directMappedPatch; nFaces 30; startFace 0; //startFace 27238; sampleMode nearestFace; sampleRegion region0; samplePatch none; offset (0.05 0 0); } outlet { type patch; nFaces 57; startFace 27268; } upperWall { type wall; nFaces 275; startFace 27325; } lowerWall { type wall; nFaces 302; startFace 27600; } frontAndBack { type empty; nFaces 27570; startFace 27902; } ) |
This is the mistake, It can run for some steps , but the courant number become larger and larger. but for the same case , courant number is very small for nearestCell mode.
Starting time loop Reading/calculating field UMean Reading/calculating field pMean Reading/calculating field UPrime2Mean Reading/calculating field pPrime2Mean fieldAverage: starting averaging at time 0 Time = 1e-05 Courant Number mean: 0.024204 max: 1.13764 DILUPBiCG: Solving for Ux, Initial residual = 0.00135981, Final residual = 1.04805e-07, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00141252, Final residual = 7.49693e-06, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0499349, No Iterations 194 time step continuity errors : sum local = 8.7322e-06, global = 6.38996e-08, cumulative = 6.38996e-08 DICPCG: Solving for p, Initial residual = 0.127359, Final residual = 8.65339e-07, No Iterations 226 time step continuity errors : sum local = 1.94082e-08, global = -1.3159e-10, cumulative = 6.3768e-08 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 7.12535e-09, No Iterations 3 bounding k, min: 0 max: 2e-05 average: 4.83687e-11 ExecutionTime = 1.16 s ClockTime = 1 s Calculating averages Time = 2e-05 Courant Number mean: 0.000585711 max: 0.871542 DILUPBiCG: Solving for Ux, Initial residual = 0.303857, Final residual = 1.61598e-08, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 0.114333, Final residual = 7.83029e-08, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.898325, Final residual = 0.0369587, No Iterations 2 time step continuity errors : sum local = 0.00592267, global = -0.000124207, cumulative = -0.000124144 DICPCG: Solving for p, Initial residual = 0.0244231, Final residual = 9.83326e-07, No Iterations 226 time step continuity errors : sum local = 3.02535e-07, global = -7.0775e-10, cumulative = -0.000124144 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 4.89965e-06, No Iterations 6 bounding k, min: 0 max: 25.3168 average: 0.0532316 ExecutionTime = 1.68 s ClockTime = 2 s Calculating averages Time = 3e-05 Courant Number mean: 0.0246538 max: 36.0409 DILUPBiCG: Solving for Ux, Initial residual = 0.294253, Final residual = 4.29506e-06, No Iterations 16 DILUPBiCG: Solving for Uy, Initial residual = 0.458164, Final residual = 3.0518e-06, No Iterations 16 DICPCG: Solving for p, Initial residual = 0.492606, Final residual = 0.0206054, No Iterations 5 time step continuity errors : sum local = 0.00579525, global = 4.14652e-05, cumulative = -8.26792e-05 DICPCG: Solving for p, Initial residual = 0.773387, Final residual = 9.1193e-07, No Iterations 221 time step continuity errors : sum local = 7.8813e-07, global = -2.04419e-10, cumulative = -8.26794e-05 DILUPBiCG: Solving for k, Initial residual = 0.999976, Final residual = 6.80055e-06, No Iterations 21 bounding k, min: -3.20149e+07 max: 4.00063e+07 average: 95738.9 ExecutionTime = 2.26 s ClockTime = 2 s Calculating averages Time = 4e-05 Courant Number mean: 0.315197 max: 1068.95 DILUPBiCG: Solving for Ux, Initial residual = 0.979042, Final residual = 9.4061e-06, No Iterations 18 DILUPBiCG: Solving for Uy, Initial residual = 0.949818, Final residual = 8.38876e-06, No Iterations 18 DICPCG: Solving for p, Initial residual = 0.827225, Final residual = 0.0301906, No Iterations 13 time step continuity errors : sum local = 0.0169686, global = -0.000103875, cumulative = -0.000186555 DICPCG: Solving for p, Initial residual = 0.85666, Final residual = 8.15768e-07, No Iterations 232 time step continuity errors : sum local = 2.46641e-06, global = -5.16787e-09, cumulative = -0.00018656 DILUPBiCG: Solving for k, Initial residual = 0.978689, Final residual = 4.5579e-06, No Iterations 15 bounding k, min: -1.10588e+09 max: 4.91812e+09 average: 1.17185e+07 ExecutionTime = 2.84 s ClockTime = 3 s Calculating averages Time = 5e-05 Courant Number mean: 1.41046 max: 1555.81 DILUPBiCG: Solving for Ux, Initial residual = 0.924203, Final residual = 1.62506e-06, No Iterations 16 DILUPBiCG: Solving for Uy, Initial residual = 0.94029, Final residual = 5.49383e-06, No Iterations 15 DICPCG: Solving for p, Initial residual = 0.913204, Final residual = 0.0450328, No Iterations 19 time step continuity errors : sum local = 0.109966, global = -0.00022542, cumulative = -0.00041198 DICPCG: Solving for p, Initial residual = 0.596696, Final residual = 9.26406e-07, No Iterations 238 time step continuity errors : sum local = 9.56009e-06, global = 1.13432e-08, cumulative = -0.000411968 DILUPBiCG: Solving for k, Initial residual = 0.662062, Final residual = 5.35556e-06, No Iterations 16 bounding k, min: -1.99423e+08 max: 1.8116e+10 average: 2.58451e+07 ExecutionTime = 3.42 s ClockTime = 3 s Calculating averages Time = 6e-05 Courant Number mean: 5.72067 max: 3297.35 DILUPBiCG: Solving for Ux, Initial residual = 0.923302, Final residual = 6.99527e-06, No Iterations 37 DILUPBiCG: Solving for Uy, Initial residual = 0.929089, Final residual = 6.33574e-06, No Iterations 34 DICPCG: Solving for p, Initial residual = 0.409462, Final residual = 0.0197329, No Iterations 42 time step continuity errors : sum local = 0.379714, global = -8.4655e-06, cumulative = -0.000420434 DICPCG: Solving for p, Initial residual = 0.939138, Final residual = 8.8431e-07, No Iterations 313 time step continuity errors : sum local = 0.000222557, global = -6.49959e-09, cumulative = -0.00042044 DILUPBiCG: Solving for k, Initial residual = 0.998731, Final residual = 3.47805e-06, No Iterations 69 bounding k, min: -6.69884e+12 max: 2.40664e+13 average: 2.25661e+11 ExecutionTime = 4.22 s ClockTime = 4 s Calculating averages Time = 7e-05 Courant Number mean: 436.283 max: 1.17029e+06 DILUPBiCG: Solving for Ux, Initial residual = 0.995348, Final residual = 9.2986e-06, No Iterations 57 DILUPBiCG: Solving for Uy, Initial residual = 0.992744, Final residual = 6.17724e-06, No Iterations 54 DICPCG: Solving for p, Initial residual = 0.487341, Final residual = 0.02222, No Iterations 25 time step continuity errors : sum local = 3.22783, global = -0.00159004, cumulative = -0.00201048 DICPCG: Solving for p, Initial residual = 0.10418, Final residual = 8.93725e-07, No Iterations 299 time step continuity errors : sum local = 0.0078815, global = 6.62659e-05, cumulative = -0.00194422 DILUPBiCG: Solving for k, Initial residual = 0.94952, Final residual = 7.63282e-06, No Iterations 69 bounding k, min: -5.5737e+13 max: 9.88183e+14 average: 2.78675e+12 ExecutionTime = 5.05 s ClockTime = 5 s Calculating averages Time = 8e-05 Courant Number mean: 1395.91 max: 2.24264e+06 DILUPBiCG: Solving for Ux, Initial residual = 0.964108, Final residual = 0.000784567, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.96877, Final residual = 0.328677, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.988575, Final residual = 0.251688, No Iterations 1001 time step continuity errors : sum local = 432823, global = -0.00106481, cumulative = -0.00300903 DICPCG: Solving for p, Initial residual = 0.995421, Final residual = 0.61434, No Iterations 1001 time step continuity errors : sum local = 5.2277e+08, global = 0.0130431, cumulative = 0.0100341 DILUPBiCG: Solving for k, Initial residual = 0.999993, Final residual = 177.682, No Iterations 1001 bounding k, min: -1.62152e+26 max: 3.6456e+27 average: 3.17189e+23 ExecutionTime = 11.18 s ClockTime = 11 s Calculating averages Time = 9e-05 Courant Number mean: 2.34159e+09 max: 2.46191e+12 DILUPBiCG: Solving for Ux, Initial residual = 0.999974, Final residual = 192336, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.999985, Final residual = 1.85635, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 1.7607, No Iterations 1001 time step continuity errors : sum local = 1.06145e+20, global = 4.30835e+12, cumulative = 4.30835e+12 DICPCG: Solving for p, Initial residual = 0.0924095, Final residual = 0.998441, No Iterations 1001 time step continuity errors : sum local = 2.50599e+23, global = 7.6643e+15, cumulative = 7.66861e+15 #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/printStack.C:202 #1 Foam::sigFpe::sigFpeHandler(int) at ~/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/signals/sigFpe.C:127 #2 ?? in "/lib64/libc.so.6" #3 Foam::NVDTVD::r(double, double, double, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/NVDTVD.H:117 #4 Foam::limitedLinearLimiter<Foam::NVDTVD>::limiter( double, double, double const&, double const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/limitedLinear.H:93 #5 Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/LimitedScheme.C:85 #6 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/limitedSurfaceInterpolationScheme.C:208 #7 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/gaussConvectionScheme.C:75 #8 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvmDiv.C:60 #9 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvmDiv.C:86 #10 Foam::incompressible::LESModels::oneEqEddy::correc t(Foam::tmp<Foam::GeometricField<Foam::Tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/LES/oneEqEddy/oneEqEddy.C:110 #11 Foam::incompressible::LESModel::correct() at ~/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/LES/LESModel/LESModel.C:154 #12 main at ~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/pisoFoam/pisoFoam.C:130 #13 __libc_start_main in "/lib64/libc.so.6" #14 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception |
In OpeFOAM's own tutorial, tutorials/incompressible/pisoFoam/les/pitzDailyDirectMapped,
I just change "nearestCell" to "nearestFace" in boundary file, but has the following error: Courant Number mean: 0.024204 max: 0.660037 --> FOAM FATAL ERROR: start 27238 out of range 0 ... 29 From function UList<T>::checkStart(const label) in file /home/yoshie27-openfoam/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/UListI.H at line 77. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/printStack.C:202 #1 Foam::error::abort() at ~/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/error.C:249 #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/errorManip.H:86 #3 Foam::UList<Foam::Vector<double> >::checkStart(int) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/UListI.H:81 #4 Foam::SubList<Foam::Vector<double> >::SubList(Foam::UList<Foam::Vector<double> > const&, int, int) at ~/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/SubListI.H:60 #5 Foam::List<Foam::Vector<double> >::subList const Foam::fvPatch::patchSlice<Foam::Vector<double> >(Foam::List<Foam::Vector<double> > const&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvPatch.H:189 #6 Foam::directMappedFixedValueFvPatchField<Foam::Vec tor<double> >::updateCoeffs() in "/home/yoshie27-openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPDebug/libfiniteVolume.so" #7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs() in "/home/yoshie27-openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPDebug/libincompressibleLESModels.so" #8 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/home/yoshie27-openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPDebug/libincompressibleLESModels.so" #9 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/finiteVolume/laplacianSchemes/gaussLaplacianScheme/gaussLaplacianScheme.C:63 #10 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/finiteVolume/laplacianSchemes/gaussLaplacianScheme/gaussLaplacianSchemes.C:113 #11 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/yoshie27-openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPDebug/libfiniteVolume.so" #12 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvmLaplacian.C:219 #13 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvmLaplacian.C:251 #14 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) at ~/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvmLaplacian.C:264 #15 Foam::incompressible::LESModels::GenEddyVisc::divD evBeff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/LES/GenEddyVisc/GenEddyVisc.C:94 #16 Foam::incompressible::LESModel::divDevReff(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ~/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/LES/LESModel/LESModel.H:240 #17 main at ~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/pisoFoam/pisoFoam.C:69 #18 __libc_start_main in "/lib64/libc.so.6" #19 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Aborted It said "start 27238 out of range 0 ... 29". So it seems that we should use: nFaces 30; startFace 0; sampleMode nearestFace; or nFaces 30; startFace 0; sampleMode nearestCell; why startFace should be 0 when using nearestFace ? when using "startFace 0" , simulation can begin, but the courant number is very large, and several steps later, crashed. Can anybody give me some suggestions ? Thanks. |
This is not a bug - you cannot change the startFace in the boundary file, this is part of the mesh description.
Changing the sampleMode to nearestFace means that now the underlying directMappedPatch returns face labels instead of cell labels. The boundary condition does not know this and just uses these incorrect labels to index the field. You will have to write your own boundary condition if you want to map from a surfaceField (on faces). Thanks, Mattijs |
Dear mattijs ,
Thank you very much. You means nearestFace can't be used at all ? I should write my own boundary condition totally ? How can I modify to make nearestFace method can be used ? I have tested this condition, the error just come from the last part. newValues = this->patch().patchSlice(allValues); here has problem. case directMappedPatchBase::NEARESTFACE: { Field<Type> allValues(nbrMesh.nFaces(), pTraits<Type>::zero); const fieldType& nbrField = nbrMesh.lookupObject<fieldType> ( fldName ); forAll(nbrField.boundaryField(), patchI) { const fvPatchField<Type>& pf = nbrField.boundaryField()[patchI]; label faceStart = pf.patch().patch().start(); forAll(pf, faceI) { allValues[faceStart++] = pf[faceI]; } } mapDistribute::distribute ( Pstream::defaultCommsType, distMap.schedule(), distMap.constructSize(), distMap.subMap(), distMap.constructMap(), allValues ); // Here can't pass newValues = this->patch().patchSlice(allValues); break; } |
