-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   regular exp in parallel rhoPimple setup (http://www.cfd-online.com/Forums/openfoam-bugs/78957-regular-exp-parallel-rhopimple-setup.html)
braennstroem August 7, 2010 08:28
it seems that in 1.7x the regular expressions in the 'T' field are not recognized by the thermo libraries in parallel. I get this error:
Reading thermophysical properties Selecting thermodynamics package hPsiThermo [2] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 [1] #0 Foam::error::printStack(Foam::Ostream&)Foam::error ::printStack(Foam::Ostream&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/ in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"linux64GccDPOpt/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigFpeHandler(int)[0] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #2 in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" [0] #2 in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #2 in "/lib/libc.so.6" [2] #3 Foam::hPsiThermo::calculate() in "/lib/libc.so.6" [1] #3 Foam::hPsiThermo::calculate() in "/lib/libc.so.6" [0] #3 Foam::hPsiThermo::calculate() in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [2] #4 Foam::hPsiThermo::hPsiThermo(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [1] #4 Foam::hPsiThermo::hPsiThermo(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [0] #4 Foam::hPsiThermo::hPsiThermo(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [2] #5 Foam::basicPsiThermo::addfvMeshConstructorToTable: :New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [1] #5 Foam::basicPsiThermo::addfvMeshConstructorToTable: :New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [0] #5 Foam::basicPsiThermo::addfvMeshConstructorToTable: :New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [2] #6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [1] #6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [0] #6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [2] #7 in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" [1] #7 in "/home/gcae504/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" Basically, I just copied my field files from serial to the snappyHexMesh-processor directories, e.g. for 'T': internalField uniform 293; boundaryField { ".*" { type zeroGradient; } "SYM.*" { type symmetryPlane; } inlet { type fixedValue; value $internalField; } outlet { type inletOutlet; value $internalField; inletValue $internalField; } "procBoundary.*" { type processor; } }
It works by using decompose -fields
Maybe, I missed something... Regards! Fabian
braennstroem August 7, 2010 13:20
maybe, this is easier to read:
imensions      [0 0 0 1 0 0 0];
boundaryField
        type            zeroGradient;
    "SYM.*"
        type            symmetryPlane;
    inlet
        type            fixedValue;
    outlet
        type            inletOutlet;
    "procBoundary.*"
        type            processor;
braennstroem August 7, 2010 13:38
Sorry my mistake... the procBoundary needs an 'value uniform $internalField'
"procBoundary.*"
type processor;
Regards!
