Dynamic_cast failing while postprocessing with paraFoam |
August 13, 2008, 09:02 |
Version: 1.5
When trying to
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Version: 1.5
When trying to postprocess a case with my own boundary conditions that are included using libs ( "libcompressibleFluxBCs.so" ); in system/controlDict. paraFoam fails when loading the data with this very strange fatal error: Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListIdEEEE From function dynamicCast<to>(From&) in file /home/bgschaid/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/typeInfo.H at line 87. (Note that the types in the error message are identical). The case loads OK when I comment out the libs entry OR when I modify the entry to libs ( "libOpenFOAM.so" "libcompressibleFluxBCs.so" ); but not when I modify it to libs ( "libcompressibleFluxBCs.so" "libOpenFOAM.so"); So obviously I have to force libOpenFOAM.so to be loaded before the UDFs. As all my systems are CentOS 5 with 64 bit I can't check whether this is a problem with the ld of that system or a general problem Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 13, 2008, 11:42 |
Had the same problem but hadn'
Mattijs Janssens
Rep Power: 26 |
Had the same problem but hadn't found out that workaround. The interesting bit is that it works for normal OF execution.
Paraview uses 'dlopen' to load the OpenFOAM reader which then does a dlopen to load those libraries. Is there something on dlopen where recursive invocation resets some flags (RTLD_LOCAL etc)? Or maybe bug? |
August 13, 2008, 12:40 |
Hi Mattijs!
It gets more my
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Mattijs!
It gets more mysterious. I tried it on my Mac and there it works without the workaround. I checked: dlopen is called with the same parameters there. So I guess the problem is with the glibc-implementation of dlopen Bernhard
August 20, 2010, 17:37 |
#4 | |
Silvano
Rep Power: 15 |
I'm trying to run the test case of "alternateReactingFoam solver" which use the "libcompressibleFluxBCs.so", but I don't have it installed on computer. So I get the warming: Code:
--> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load libcompressibleFluxBCs.so: cannot open shared object file: No such file or directory thank you! Silvano |
Display Modes | |
[OpenFOAM] Install paraFoam on Windows for postprocessing | melanie | ParaView | 11 | March 13, 2010 18:44 |
[OpenFOAM] ParaFOAM | ttdtud | ParaView | 2 | May 29, 2008 10:08 |
[OpenFOAM] ParaFoam | nzy102 | ParaView | 0 | April 13, 2007 21:15 |
ParaFoam | Ales Alajbegovic (Alajbegovic) | OpenFOAM Installation | 13 | November 7, 2006 10:44 |
Adaptation failing in // Fluent case? | Riaan | FLUENT | 0 | February 3, 2006 15:57 |
