Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OF-1.7.x: dynamicMesh parallel solving fail
Old   October 12, 2010, 11:19
Smile OF-1.7.x: dynamicMesh parallel solving fail
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Is it a known issue or not.
When I was using pimpleDyMFoam, I found if I decompose the case and run it in parallel, it will fail sometimes at certain time point, but as I reconstruct the the results at its latest time and run it in serial, it seems everything works perfect and goes on for a long time.
The error is sth like:
[2]
[2]
[2] --> FOAM FATAL ERROR:
[3] [2] face 1041 and 3263 areas do not match by 0.0101863% -- possible face ordering problem
[2]
[2]     From function cyclicFvPatch::makeWeights(scalarField& w) const
[2]     in file fvMesh/fvPatches/constraint/cyclic/cyclicFvPatch.C at line 57.
[2]
FOAM parallel run aborting
[2]
[3]
[3] --> FOAM FATAL ERROR:
[3] face 842 and 3051 areas do not match by 0.0101899% -- possible face ordering problem
[3]
[3]     From function cyclicFvPatch::makeWeights(scalarField& w) const
[3]     in file fvMesh/fvPatches/constraint/cyclic/cyclicFvPatch.C at line 57.
[3]
Have a good day!
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   October 12, 2010, 11:31
lakeat's Avatar
Daniel WEI (老魏)
Oops, in serial running, it failed again.
face 5789 and 14669 areas do not match by 0.0101915% -- possible face ordering problem
Any conflicts with cyclic B.C. setting?
Daniel WEI
Beijing, China
Email
Old   October 12, 2010, 11:39
lakeat's Avatar
Daniel WEI (老魏)
Oh, every time it fails, I switch the solver between displacementLaplacian and displacementSBRStress to make it go again. That's funny
Daniel WEI
Beijing, China
Email
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
