Bug in UEqn of twoPhaseEulerFoam?
Hi All:
I've spent some time interpreting the UEqn.C of twoPhaseEulerFoam. The momentum equation seems OK. however, the drag term seems problematic: See the following link for the standard momentum equation. http://openfoamwiki.net/index.php/BubbleFoam In the UEqn.H, the momentum equation is : Quote:
I've tried to implement that (Ub-Ua), I just added the following line in the rhs: + fvm::Sp(beta/rhoa*K, Ub) For the UbEqns, I've done a similar modification Am I right? Anyone can help? |
The explicit part of the drag that contains Ub has been transferred to pEqn.H. Have a look there and see if it makes sense to you.
Thank you!
Yes, Thanks for your reply, it really helps!
The effect of particle-particle interaction is also included if we set g0>0, However, note that there is g0 in radial Model (we get g0 and g0Prime), and we also define g0 in ppProperties. Both alphaEqn.H and pEqn.H are using phi_pp, which involves g0, So which g0 are they using? Thank you in advance. Zhen |
If you use the kinetic theory model, you should set g0 in ppProperties to zero.
Hi Alberto
I am reading the code of kineticTheory in twoPhaseEulerFoam. I find there are some annotation in kineticTheory.C such as "construct the granular temperature equation (Eq. 3.20, p. 44)" in line 61. So, can you tell me which book include these equation. Furthermore, where can I find the theory about g0 in ppProperties! |
Best, |
Does anyone know how to get the van Wachem Thesis? There's nothing online. Does anyone have a pdf?
http://repository.tudelft.nl/view/ir...-83b1416709a6/ enjoy! Florian |
Oh dear! I was googling for ages but couldnt find it...!
Thanks for proving me wrong! :o |
