Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Possible bug in fvMatrix residual member
Old   April 14, 2011, 03:46
Default Possible bug in fvMatrix residual member
Luca M.
luca is on a distinguished road
supposing that the fvMatrix.residual() member give us the residual of the matrix in the form R = Ax - B, I've noticed a strange behavior.
In some way .residual() member applied to fvMatrix<vector> modifies the extra diagonal elements of the matrix:
the operator .H() returns different results for fvMatrix<vector> before and after calling the fvMatrix.residual() member.
Attached you find a simple code to reproduce the "phenomena" , you can run it under tutorial directory of the scalarTransportFoam solver
Tested on 1.7.x version yesterday update
scalarTransportFoam.C
Thanks in advance
luca is offline   Reply With Quote
Old   June 6, 2011, 04:35
Luca M.
Hello
I was wondering why after two months nobody of the developers reply to this post..
Anyway for the guys that need residual() functions works properly I figure out the error:
Change in file fvMatrixSolve.C the line 192 with:
tmp<Field<Type> > tres(new Field<Type>(source_));
in this way there is no more modification of the source term (that was the problem).
Regards
Luca
P.S.
you have to patch only the 1.7 official release
Old   June 6, 2011, 05:12
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
If you think there's a bug then post it here (as mentioned in the sticky thread in this forum):
http://www.openfoam.com/mantisbt
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
