-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Write interval not in exact number (http://www.cfd-online.com/Forums/openfoam-bugs/87805-write-interval-not-exact-number.html)
cwang5 April 29, 2011 08:09
Hi guys,
I've been using OpenFOAM for a while, and this is the first time that I've encountered this minor but annoying problem. I have set my "writeControl" to "runTime" with interval of 0.1, which should write the simulation results in 0.1s intervals (0, 0.1, 0.2 etc.), but instead I'm getting folders for 0, 0.0999999999, 0.19999999 etc. It's rather easy, but time consuming to fix by renaming all the folders, but I'm wondering if there is a way to make sure all folders are named for the specified time in controlDict.
Thanks,
John
p.s. I do not use adjustable time step option as it sometimes enforces very very small time steps (1e-9) and unnecessarily slow down the simulation process (compare to the same simulation using constant time step of 1e-6 without running into any problem).
alberto April 30, 2011 02:23
Maybe post your controlDict settings. It would be of help.
cwang5 May 3, 2011 06:06
Sorry for the delay in reply, the email notification probably ended up in spammail box and I forgot to check the forum until today. The maxCo was required by the solver for some reason, but shouldn't effect the writeControl, right?
Here's my controlDict:
application    pimpleDyMFoam;
startFrom      startTime;
startTime      0;
stopAt          endTime;
endTime        10;
deltaT          2e-06;
writeControl runTime;
writeInterval  0.1;
purgeWrite      0;
writeFormat    binary;
writePrecision  12;
writeCompression uncompressed;
timeFormat      general;
timePrecision  12;
runTimeModifiable yes;
adjustTimeStep  no;
maxCo          0.05;
maxDeltaT      1e-6;
alberto May 4, 2011 00:03
Try:
writeControl adjustableRunTime;
Best,
cwang5 May 31, 2011 20:43
Thanks for the input, tried that, same result, though =/
I've renamed all the folders manually already, anyway.
On a side note, I really should check my thread subscription notification setting, I did not see your post until today.
John
musahossein November 28, 2014 17:35
writeInterval in OpenFOAM does not always write at the desired time
I have had problems with writeInterval as weel. Even if I specify 0.02 time for the writeInterval I may get a file that say instead of having the time stamp 21.20, will have a timeStamp of 21.219999. After fiddling around with the problem, I noted that in controlDcit if I change the precision to 7 in the following section of controlDict, I dont have that problem any more. I suppose that allowing more digits after the decimal, OpenFOAM as enough digits to upgrade to the next integer:
stuff deleted
writeInterval 0.02;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression compressed;
timeFormat general;
timePrecision 7;
runTimeModifiable no;
adjustTimeStep yes;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
.stuff deleted
wyldckat December 13, 2014 21:41
Quick question @musahossein: Which specific OpenFOAM version are you using? Because the more recent versions are meant to have this issue already fixed.
edit: Looks like this is related to this thread: http://www.cfd-online.com/Forums/ope...tml#post520710
musahossein December 15, 2014 09:11
I am using version 2.2.1.
