-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   rhoPimpleFoam printStack error (http://www.cfd-online.com/Forums/openfoam-bugs/88426-rhopimplefoam-printstack-error.html)
atoof May 17, 2011 10:29
1 Attachment(s)
Hi Foamers,
I run a case for two inlet air with different temperatures in a channel.
I set 0 directory as attached files.
When I use rhoPimpleFoam as a solver I faced to this error:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::calcMut() const in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#4 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) at /opt/openfoam171/src/finiteVolume/lnInclude/fvPatchField.C:222
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at /opt/openfoam171/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:306
#7 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#8 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#9 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#10 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::RASMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleTurbulenceModel.so"
#12
at /opt/openfoam171/applications/solvers/compressible/rhoPimpleFoam/createFields.H:57
#13 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#14
in "/opt/openfoam171/applications/bin/linuxGccDPOpt/rhoPimpleFoam"
Floating point exception
I guess the problem is about k-epsilon setting in 0 directory, but I don't know where is the problem.:confused:
How can I remove this error?
Regards,
Hossein
