OF 1.6-ext interDyMFoam damBreakWithObstacle tutorial crashes
Hi all,
after recently switching from OF 1.7.x to 1.6-ext, I'm now struggling with some problems running the tutorials for the interDyMFoam solver. At least the damBreakWithObstacle tutorial crashes for OF-1.6-ext in serial and parallel mode, whereas everything runs fine in OF 1.7.x. All bug fixes (at least for the master branch) are included in my current OF version. Coming to the errors messages: 1. In dambreakWithObstacle (running via Allrun), I get (in single and parallel mode) Quote:
2. Running the floatingObject tutorial, I get Quote:
You can take a look at recent runs of the OpenFOAM-1.6-ext test harness: http://openfoam-extend.sourceforge.n...ate=2011-05-24 One can see that this specific tutorial is running fine under OpenFOAM-1.6-ext, using various OS flavors, including Ubuntu 10.10. Please take a look at my comments on the Bug tracking system for OpenFOAM-1.6-ext. Martin Quote:
Martin,
Doesn't the test-harness run each tutorial for only one time-step? |
Yup, your are right.
Running this tutorial for more than one time step on my system, I can reproduce the problem as well, at t=0.0280313, with a nice Segmentation fault. So there is indeed a problem with this tutorial. Martin Quote:
Dear colleagues,
is there any update on this issue? Best regards, Aleksey. P.S. All my trials to use dynamicRefineFvMesh possibilities in OF-1.6-ext failed due to segmentation fault on early steps of calculation. |
