-   OpenFOAM Bugs (http://www.cfd-online.com/Forums/openfoam-bugs/)
-   -   Cylinder and dsmc solver (http://www.cfd-online.com/Forums/openfoam-bugs/90157-cylinder-dsmc-solver.html)
sandre July 2, 2011 06:53
Hi!
I've made cylinder geometry via blockmesh utility and started dsmc solver, but the process have eaten too much memory and show an error exception:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted
Same case with cube geometry solve good.
Can you help me, please?
blockMeshDict file:
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      blockMeshDict;
convertToMeters 0.01;
vertices
(-1 -1 -1)
(1 -1 -1)
(1 1 -1)
(-1 1 -1)
(-1 -1 1)
(1 -1 1)
(1 1 1)
(-1 1 1)
blocks
    hex (0 1 2 3 4 5 6 7) (5 5 5) simpleGrading (1 1 1)
edges
  arc 0 1 (0 -1.4142135623730951 -1)
  arc 1 2 (1.4142135623730951 0 -1)
  arc 2 3 (0 1.4142135623730951 -1)
  arc 3 0 (-1.4142135623730951 0 -1)
  arc 4 5 (0 -1.4142135623730951 1)
  arc 5 6 (1.4142135623730951 0 1)
  arc 6 7 (0 1.4142135623730951 1)
  arc 7 4 (-1.4142135623730951 0 1)
patches
    patch sides
        (1 5 4 0)
    (0 4 7 3)
        (2 6 5 1)
        (3 7 6 2)
    patch inlet
      (0 3 2 1)
    patch outlet
        (4 5 6 7)
mergePatchPairs
anon_a October 13, 2011 08:08
Sounds like you have too many particles.
The information you have posted is not sufficient.
Could you also post the contents of constant/dsmcProperties ?
