error propeller case
I encounter a problem when running the propeller tutorial with the pimpleDyMFoam solver. The problem occurs during the mesh generation process with the 'topoSet' command.
When I do the command: topoSet -dict system/removeRedundantZones.topoSetDict I get the following error message: --------------------------------------------------------- Create time Create polyMesh for time = 0 Reading topoSetDict Time = 0 mesh not changed. --> FOAM FATAL ERROR: object is not allocated From function T& Foam::autoPtr<T>::operator()() in file /shared/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/autoPtrI.H at line 118. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/topoSet" #3 __libc_start_main in "/lib64/libc.so.6" #4 at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/x86_64/elf/start.S:116 Abort --------------------------------------------------------- Has someone experienced the same kind of error ? Some days ago I was able to run the tutorial without any errors ! Best regards, Stephane. |
Greetings Stephane,
I think the problem is related to the following modification: https://github.com/OpenFOAM/OpenFOAM...e9db7af6d19b40 Please report this on the official bug tracker: http://www.openfoam.com/mantisbt/my_view_page.php ;) Best regards, Bruno |
| All times are GMT -4. The time now is 22:54. |
