Home > Forums > OpenFOAM Bugs
Sign inconsistency in the compressible Launder-Sharma k-epsilon model
Like Tree1Likes
  • 1 Post By vkrastev
Old   March 15, 2012, 06:15
Default Sign inconsistency in the compressible Launder-Sharma k-epsilon model
Vesselin Krastev
vkrastev is on a distinguished road
Hi all,
checking the epsilon transport equation in the Launder-Sharma low-Re model I've found a clear inconsistency in the C3 constant sign (at least it is there in the OF-2.1.0 release, I don't know if it has been already fixed in 2.1.x).
The following is the (correct) compressibility production term in the standard k-epsilon model implementation:
- fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_)
As you can see, the term multiplied by C1 enters with a negative sign, while the term multiplied by C3 actually becomes positive, as in OF C3 is equal to -0.33 while the correct constant value in the RHS of the epsilon equation should be +0.33.
This is the same (incorrect) term in the Launder-Sharma model:
+ fvm::SuSp((C3_ - 2.0/3.0*C1_)*rho_*divU, epsilon_)
The C1 term is again negative, but so it is the C3 one as in OF +C3=-0.33.
So, I don't know what is the real influence of such an error, but to me this is clearly a bug (I will report it to the bug tracker in a while).
Greetings to all
V.
(Reported)
http://www.openfoam.org/mantisbt/view.php?id=462
immortality likes this.
Last edited by vkrastev; March 15, 2012 at 06:23. Reason: Bug tracker reference added
vkrastev is offline   Reply With Quote
Thread Tools
Trackbacks are On
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... RSilva Main CFD Forum 17 February 17, 2014 10:52
Herschel-Bulkley non-Newtonian viscosity model has term with sign error pbryant OpenFOAM Bugs 5 June 18, 2013 23:53
derivation of epsilon equation of k-epsilon model Ricardo Rezende Main CFD Forum 5 May 1, 2007 05:38
Wall Boundary Condition in k - epsilon model abhijeet vaidya Main CFD Forum 0 July 14, 2002 03:18
Launder & Sharma model in combusion case Richard Carroni Main CFD Forum 1 November 17, 1998 19:59
