alphaContactAngle patch type does not work in OF-1.6 |
September 24, 2009, 20:14 |
Denis Semyonov
Rep Power: 17 |
Hello, everybody.
I found out that the new patch type alphaContactAngle which has replaced previously used constantGammaContactAngle for the interFoam solver does not work properly. Consider given tutorial example damBreak using laminar turbulence model. If you follow the User Guide and replace in the 0/alpha1 file any wall boundary patch from zeroGradient to something like: Code:
boundaryField { leftWall { // type zeroGradient; type alphaContactAngle; theta0 40; thetaA 70; thetaR 10; uTheta 1; value uniform 1; } ... Code:
damBreak> interFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : interFoam Date : Sep 25 2009 Time : 02:56:41 Host : kowalski PID : 18331 Case : /home/semyonov/OpenFOAM/semyonov-1.6/run/damBreak nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Not Implemented Trying to construct an genericFvPatchField on patch leftWall of field rho#0 Foam::error::printStack(Foam::Ostream&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::genericFvPatchField<double>::genericFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #3 Foam::fvPatchField<double>::addpatchConstructorToTable<Foam::genericFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam" #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::List<Foam::word> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam" #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::List<Foam::word> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam" #7 main in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam" #8 __libc_start_main in "/lib64/libc.so.6" #9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 45. FOAM aborting Aborted Just in case I have also tried to set this patch to constantGammaContactAngle and alpha1ContactAngle, but neither works. I am not very familiar with the source code. How can I check the list of the available and implemented boundary patche types? Denis |
September 25, 2009, 04:04 |
Rep Power: 22 |
alphaContactAngle is the abstract base-type with concrete implementations:
constantAlphaContactAngle dynamicAlphaContactAngle timeVaryingAlphaContactAngle I think you need constantAlphaContactAngle for your case. H |
September 25, 2009, 04:51 |
Björn Fabritius
Rep Power: 17 |
different case, similar problem:
I tried to convert a OF 1.5-dev case with moving mesh to OF 1.6. First of all: Why is it that I now have to provide cellMotionU AND pointMotionU when using the velocityLaplacian motionSolver instead of just giving motionU as of version 1.5? But the real problem is that I used the oscillatingFixedValue b.c. on a patch for movement, but that leads to Code:
Not Implemented Trying to construct an genericFvPatchField on patch topStamp of field cellMotionU#0 Any ideas how to use this or another b.c. that does the same job with a moving wall? tx, bjoern |
September 25, 2009, 12:41 |
Denis Semyonov
Rep Power: 17 |
Thank you, Henry.
Suggestet patch types working well in the damBreak example of OF-1.6. I guess it was just too late yesterday, so I forgot to simply replace constantGammaContactAngle with the constantAlphaContactAngle and thought that there is something wrong with OpenFOAM installation. Denis |
December 8, 2009, 03:40 |
Not yet figured out!
Claus Meister
Rep Power: 17 |
Hello sundaero!
Could you please post your final alpha1 file with the modified contact angle? Because I haven not yet figured out how it works. Cheers, Claus |
December 8, 2009, 09:14 |
Denis Semyonov
Rep Power: 17 |
Here it goes (implementation of the dynamic contact angle):
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha1; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { FRONT_WALL { type empty; } BACK_WALL { type empty; } OUTLET { type inletOutlet; inletValue uniform 0; value uniform 0; } GAS_INLET { type fixedValue; value uniform 0; } CATALYST { type dynamicAlphaContactAngle; theta0 40; thetaA 70; thetaR 10; uTheta 1; value uniform 1; } LIQUID_INLET { type zeroGradient; type fixedValue; value uniform 1; } TOP_WALLS { type zeroGradient; } LEFT_RIGHT { type cyclic; value uniform 1; } } // ************************************************************************* // Denis |
June 16, 2010, 11:11 |
Similar error, different cause
Mark Couwenberg
Rep Power: 17 |
Hello All,
I have the similar error (Not implemented, trying to construct an gFPF on patch ... of field rho#()). The error is being generated by the file genericFvPatchField.C. However, I am doing something else: I created a private boundary condition which is based on timeVaryingUniformFixedValue which is intended to be used on alpha1 field only. It compiles well. But at runtime I get that specific error. My 0/alpha1 for that specific patch looks like type surfaceWaveAlpha; value uniform 0; Because the error message is complaing about rho, I also tried adding : rho rho, without result. Can anyone give me some hints here, althoug I admit that the description might be a bit vague... Thanks in advance, Mark |
June 18, 2011, 04:45 |
azar
Rep Power: 15 |
Hi, i am realy confused
whats the meaning of the 'thataA","theta0","thetaR" and "utheta"? can you tell me a bout it briefly? tnx |
March 19, 2012, 22:23 |
#9 |
bibin
Dear Henry,
I am a new user and I am trying to implement slug-plug flow of water in oil in a 250micon closed square channel. I have a relation which goes like thetaA=thetaA0+const*Ca^(1/3) for advancing CA and thetaR=thetaR0-const*Ca^(1/3) for receding CA, both based on Tanner's law. The difference in thetaA0 and thetaR0 is the contact angle hysteresis. I am trying to understand the shape of droplets under the influence of contact angle hysteresis. Could you please explain with a sample code, if possible how to implement dynamicAlphaContactAngle in /0/alpha1. I believe it goes into the boundary condition in alpha1. Your reply is deeply appreciated. Thanks, Koooje |
April 1, 2012, 19:40 |
#10 |
bibin
Go to : opt/openfoam210/src/transportModels/twoPhaseInterfaceProperties/alphaContactAngle for the implementation of dynamicAlphaContactAngle
Check out the file 'dynamicAlphaContactAngleFvPatchScalarField.C' and 'dynamicAlphaContactAngleFvPatchScalarField.H' to find the meaning of all the parameters you asked for. The theta is specified by the formula theta=theta0_ + (thetaA_ - thetaR_)*tanh(uwall/uTheta_). If you plot this formula with matlab/mathematica you can see how theta varies with different parameters. Koooje |
April 13, 2012, 18:08 |
#11 |
Nikhil
Rep Power: 14 |
Hello Koooje,
To implement your new dynamic contact angle BC, start off by copying the existing files of dynamic contact angle implementation. You need to calculate the capillary number by creating volScalarField 'mu' in createField.H file and update it every iteration. Call the 'mu' from your new files and calculate the capillary number. Once you calculate that you can use your theta expressions. All you need to do is change the way theta is being calculated and return it to interface.C file which takes care of the correction. Hope this helps. Nikhil |
Display Modes | |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 10:54 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 12:46 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
