Home > Forums > OpenFOAM Installation on Windows, Mac and other Unsupported Platforms
Installing swak4Foam to OpenFOAM in mac
Old   January 21, 2013, 12:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by ajl42 View Post
Hi Bernhard,
I've rerun ./Allwmake. Thank you for your help, sorry for cutting and pasting but I can't upload the file at this time not sure why.
Best wishes,
Andy.
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Traceback (most recent call last):
File "./maintainanceScripts/makeSwakVersionFile.py", line 8, in <module>
output = Popen(["hg", "branch"], stdout=PIPE).communicate()[0]
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 679, in __init__
errread, errwrite)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1249, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Bison is version 2.7
Flex is version 2.5.37 (Minor version: 37)
OpenFOAM-version: Major 2 Minor 1 Patch x
No change to swak4FoamParsers/foamVersion4swak.H
SOURCE=CommonValueExpressionDriver.C ; g++-mp-4.6 -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64Gcc46DPOpt -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/Users/ajl/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/CommonValueExpressionDriver.o
CommonValueExpressionDriver.C:1309:7: error: template argument required for 'class lessOp'
CommonValueExpressionDriver.C: In member function 'Foam::vector Foam::CommonValueExpressionDriver::getPositionOfMi nimum(const scalarField&, const vectorField&) const':
CommonValueExpressionDriver.C:1374:37: error: missing template arguments before '(' token
CommonValueExpressionDriver.C: In member function 'Foam::word Foam::CommonValueExpressionDriver::getHex(const void*) const':
CommonValueExpressionDriver.C:1389:35: warning: use of old-style cast [-Wold-style-cast]
CommonValueExpressionDriver.C:1375:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/darwinIntel64Gcc46DPOpt/CommonValueExpressionDriver.o] Error 1
That seems to be the problem described in
https://sourceforge.net/apps/mantisb...iew.php?id=163
(caused by an update of the upstream sources). The other errors are following from that
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 21, 2013, 12:24
Cristiano Sousa
Beatgodes is on a distinguished road
Error maintains. I unset the WM_NCOMPPROCS for you
abort: no repository found in '/Users/beatgodes/Downloads/swak4Foam_2.x_release_0.2.1' (.hg not found)!
OpenFOAM-version: Major 2 Minor 1 Patch 1
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswak4FoamParsers.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libgroovyBC.dylib' is up to date.
Making dependency list for source file manipulatePatchField.C
SOURCE=manipulatePatchField.C ;  g++ -m64 -fsignaling-nans  -ftrapping-math -g -arch x86_64 -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -g -arch x86_64 -DNoRepository -ftemplate-depth-100  	 -I../swak4FoamParsers/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/sampling/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/triSurface/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src//postProcessing/functionObjects/utilities/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/lagrangian/basic/lnInclude  -IlnInclude -I. -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/manipulatePatchField.o
manipulatePatchField.C: In member function ‘void Foam::manipulatePatchField::manipulatePoint(const TField&, const Foam::Field<bool>&)’:
manipulatePatchField.C:143: error: request for member ‘boundaryMesh’ in ‘dynamic_cast<const Foam::fvMesh&>(this->.obr_)’, which is of non-class type ‘const Foam::fvMesh&’
make: *** [Make/darwinIntel64GccDPOpt/manipulatePatchField.o] Error 1
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libsimpleFunctionObjects.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libsimpleSwakFunctionObjects.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakTopoSources.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakSourceFields.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libgroovyStandardBCs.dylib' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakRandomFunctionPlugin.dylib' is up to date.
SOURCE=fvcInterpolationFunctionPlugin.C ;  g++ -m64 -fsignaling-nans  -ftrapping-math -g -arch x86_64 -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -g -arch x86_64 -DNoRepository -ftemplate-depth-100  	 -I../../swak4FoamParsers/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -IlnInclude -I. -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/Users/beatgodes/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/fvcInterpolationFunctionPlugin.o
fvcInterpolationFunctionPlugin.C: In member function ‘void Foam::fvcInterpolationFunctionPlugin<T>::setArgument(Foam::label, const Foam::string&, const Foam::CommonValueExpressionDriver&)’:
fvcInterpolationFunctionPlugin.C:124: error: request for member ‘getResult<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >’ in ‘dynamic_cast<const Foam::FieldValueExpressionDriver&>(driver)’, which is of non-class type ‘const Foam::FieldValueExpressionDriver&’
make: *** [Make/darwinIntel64GccDPOpt/fvcInterpolationFunctionPlugin.o] Error 1
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.dylib' is up to date.
'/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/lib/libswakVelocityFunctionPlugin.dylib' is up to date.
make[1]: `/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: `/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/bin/funkySetBoundaryField' is up to date.
make[1]: `/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/bin/funkySetFields' is up to date.
make[1]: `/Users/beatgodes/OpenFOAM/beatgodes-2.1.1/platforms/darwinIntel64GccDPOpt/bin/replayTransientBC' is up to date.
Beatgodes is offline   Reply With Quote
Old   January 21, 2013, 12:51
Andy Lowe
ajl42 is on a distinguished road
Hi Bernhard,
thank you for the link and the patch fixed my glitch.
Many thanks,
Andy.
ajl42 is offline   Reply With Quote
mac, openfoam 2.0.x, swak4foam, warning message, wmake
Thread Tools
Trackbacks are On
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
wmake in openfoam mac 1.7.x atareen64 OpenFOAM Installation 10 July 12, 2011 11:02
Installing OpenFOAM with SYSTEM MPI while using Third-Party libs m.culpo OpenFOAM Installation 5 July 3, 2011 03:48
Installing OpenFOAM 1.3 on openSUSE 10.3 aliakbar82 OpenFOAM Installation 1 December 31, 2009 04:35
OpenFOAM on mac OSX Nick Colam Main CFD Forum 3 January 27, 2009 01:06
