-   OpenFOAM Installation on Windows, Mac and other Unsupported Platforms (http://www.cfd-online.com/Forums/openfoam-installation-windows-mac/)
-   -   blockMesh: command not found - on Mac OS X (http://www.cfd-online.com/Forums/openfoam-installation-windows-mac/115775-blockmesh-command-not-found-mac-os-x.html)
nprociw@hotmail.com April 6, 2013 10:51
Hi
I have installed OpenFOAM version 2.0.x on Mac OS X as shown by the instructions given at the following link:
http://www.optimulation.com/category.../installation/
I tried to run the cavity tutorial case but I have run into the error:
-bash: blockMesh: command not found
Does anybody have a clue how to fix this problem? I am new to open foam and Mac OS so I am pretty clueless as to how to fix this issue.
Thanks
Lieven April 6, 2013 17:08
Are any of the other commands like 'simpleFoam' available?
If not, the bashrc-file is probably not loaded. Make sure to add
source OpenFOAM/OpenFOAM-2.2.0/etc/bashrc
to ~/.profile
and to reboot (or re-login) afterwards.
Cheers,
L
itsme_kit December 28, 2013 14:19
Originally Posted by nprociw@hotmail.com (Post 418767)
Hi
Thanks
Hi
Have you solved your problem already
I got the same problem too
KateEisenhower March 3, 2015 06:53
Hi everybody,
Has anybody solved this problem yet?
Cheers,
Kate
Edit: @Lieven: Unfortunately that didn't work.
Lieven March 3, 2015 07:17
Kate
Which version of OF are you using?
In which folder is it installed?
Could you perhaps post the output of
locate bashrc
Cheers,
L
KateEisenhower March 3, 2015 08:00
Originally Posted by Lieven (Post 534144)
Kate
locate bashrc
Cheers,
L
Hi Lieven,
I want to use 2.3.1 on OS X Yosemite. Haven't been successful so far.
I tried to install it in the main user folder following the steps described in this guide: http://openfoamwiki.net/index.php/In...es_and_patches
The output of
locate bashrc
is
WARNING: The locate database (/var/db/locate.database) does not exist.
To create the database, run the following command:
  sudo launchctl load -w /System/Library/LaunchDaemons/com.apple.locate.plist
Please be aware that the database can take some time to generate; once
the database has been created, this message will no longer appear.
Should I run the proposed command?
alexeym March 3, 2015 08:09
You would like to run 2.3.1 and yet use guide for 2.2.2. So please post more details about your way of installation.
To check if you have set up environment variables correctly, run in terminal:
$ export | grep -E '(FOAM_|WM_)'
If output is empty, then you have missed the step 4.3.9 in the guide (in fact you have to do this every time you start new terminal).
You could but I am not quite sure you will use locate command in the future (you have got find and Spotlight).
KateEisenhower March 3, 2015 13:10
Originally Posted by alexeym (Post 534152)
Hi alexeym,
I'd love to use a guide for 2.3.1 if I could find one. Since gschaider recommended to use the 2.2.2 guide in his post (http://www.cfd-online.com/Forums/ope...s-x-patch.html), I thought it would be fine.
When I ran
I got
-bash: $: command not found
as an answer. I don't know if this helps.
When I execute step 4.3.9 of the guide, I get the following answer:
-bash: mpicc: command not found
Using paraview in directory /Applications/paraview.app
Is this okay?
In my opinion it would be the best to clear my harddrive and start all over again.
alexeym March 3, 2015 13:37
It's OK but still it is worth to mention the guide you have used. At least now it is clear that you are using Macports and unknown patch.
When I ran
I got
$ in my post is the shell prompt, so you do not need to copy it. If you would like to have copy-paste variant, here it is:
Is this okay?
No, it is not OK. It means you have problem with OpenMPI installation. Either you have not selected default MPI installation or simply forgot to install it.
Well, if you follow the same installation guide you will end up with the same broken build. So I am not sure that this is right solution.
KateEisenhower March 5, 2015 10:02
Originally Posted by alexeym (Post 534204)
Thanks a lot for your help. I guess I have a lack of basic knowledge. Because of that I posted a question on the main 2.3 patch thread (http://www.cfd-online.com/Forums/ope...tml#post534615). Maybe I will come back to this thread later.
Thanks again,
Kate
ajmas March 15, 2015 18:54
Could you give the following script a go and let me know if it helps you:
https://github.com/ajmas/scripts-et-...sx-macports.sh
It should do much of the work for you, including creating the disk image, checking out the necessary 'Mac Ports', checking out the patched source for MacOS X and building the project. It is still a work in progress, but hopefully it should remove some of the guess work.
Please let me know this helps.
