Home > Forums > OpenFOAM Installation on Windows, Mac and other Unsupported Platforms
2.1 installation on Mountain Lion help please!
Old   April 22, 2013, 12:31
Default 2.1 installation on Mountain Lion help please!
Peter Hagan
PeteH is on a distinguished road
Hi all,
I have been in the background on this forum a lot. Mostly reviewing all the problems people have had installing openFOAM. Well I finally got the courage to have a go and install it myself. I used the wiki install guide found here
http://openfoamwiki.net/index.php/Ho...enFOAM_v21_Mac
The installation process went pretty smoothly, or so I thought... When I go to run the cavity tutorial I get an error when running the paraFoam command.
Petes-MacBook-Pro-2:cavity Pete$ paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
I I cd'd to that folder and performed the Allwclean and Allwmake but get the same error when I try to run paraFoam again. Any ideas?
Also,
I tried to build ParaView from the Thirdparty2.1.1 folder and got this error:
*** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
So I tried to build the Qt in the Thirdparty2.1.1 folder and recieved this error:
Petes-MacBook-Pro-2:ThirdParty-2.1.1 Pete$ ./makeQt
Starting build: Qt-4.7.3
./makeQt: line 107: cd: /Users/Pete/OpenFOAM/ThirdParty-2.1.1/qt-everywhere-opensource-src-4.7.3: No such file or directory
Error building: Qt-4.7.3
I'm assuming this has something to do with it.
Any help would be greatly appreciated!
Thanks!
Pete
PeteH is offline   Reply With Quote
Old   April 22, 2013, 14:59
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Peter and welcome to the forum!
Did you see the chapter 3 on the instructions? Well, if they seemed to confusing, please check if the current description is better now: http://openfoamwiki.net/index.php/Ho...using_ParaView
In essence, if you follow the description on that chapter, you don't need to build ParaView from source code!
Best regards,
Bruno
PS: thanks for posting in the right forum. Next time you can use the triangle sign on the lower left corner of a post, to report a misplaced post. Or contact one of the forum admins/moderators, as listed in the main forum, at the end of the list of forums!
Old   April 22, 2013, 15:31
Peter Hagan
Thanks for the quick reply!
That got it working. I had trouble understanding if I needed a .alias file but I just put the aliases in my bashrc and that got it working.
I was able to run the blockMesh and icoFoam before but now I'm having another problem.
When trying to run blockMesh I get:
dyld: Library not loaded: /Users/Pete/OpenFOAM/ThirdParty-2.1.1/platforms/darwinIntel64Gcc46/openmpi-1.5.3/lib/libmpi.1.dylib
  Referenced from: /Users/Pete/OpenFOAM/OpenFOAM-2.1.1/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-1.5.3/libPstream.dylib
  Reason: image not found
Trace/BPT trap: 5
I went to the first directory and noticed that libPstream.dylib was there but the lib folder was not.
but it was working before???
Did I change something/recompile something that could make this happen?
Thanks for all your help!
Pete
Old   April 22, 2013, 15:52
Bruno Santos
Hi Pete,
How did you do this step: http://openfoamwiki.net/index.php/Ho...penMPI-version - when you were following the instructions for the first time?
Best regards,
Bruno
Old   April 23, 2013, 10:23
Peter Hagan
Hi Bruno,
I did that step incorrectly. I performed it again and everything seems to be working properly now! This is my first, real, in depth try at the terminal prompt so it's been a little shaky. Thanks for all the help! I'm sure you will be seeing me in the meshing section shortly!
Thanks again,
Pete
Thread Tools
Trackbacks are On
installation on mac os x lion achyutan OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 1 February 28, 2013 09:15
Installing OpenFoam 2.1.1 on OS X 10.8.2 (Mountain Lion) TomGEO OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 11 December 11, 2012 12:08
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
Problem: Openfoam 2.1 installation from git repo fertinaz OpenFOAM Installation 10 March 2, 2012 12:26
