Home > Forums > OpenFOAM Installation on Windows, Mac and other Unsupported Platforms
Installing OpenFoam2.2.2 on Mac OS X Mavericks
Old   December 18, 2013, 18:56
Default Installing OpenFoam2.2.2 on Mac OS X Mavericks
Andy Lowe
ajl42 is on a distinguished road
Hi, I've followed the wiki installation process for installing OpenFoam2.2.2 on mac os x Mavericks (Installation/Mac OS/OpenFOAM 2.2.2). There's an error early on in the process when trying to compile Scotch. I've attached the log file.
Can anyone shed light on what I've done wrong.
Many Thanks,
Andy.
ajl42 is offline   Reply With Quote
Old   December 24, 2013, 12:01
Smile Solved
Andy Lowe
Hi, I managed to solve this using the posts on this forum. Thank you to everyone that posted it helped tremendously. The main learning points for me were :
Follow the procedure mentioned above with the following tweaks:
1. use WM_MPLIB=MACPORTOPENMPI : if you have recently installed Mavericks, make sure you reinstall your ports as macports recommend. I used the +gcc46 variant for the openmpi port.
2. ensure that the options files are written correctly. I found quite a few errors where comments or carriage returns had been added. The log file can be used to find which options files are incorrect.
3. delete the /*-lsolidThermo*/ \ flag comment in the OpenFOAM2.2.2/src/fvOptions/Make/darwinIntel64Gcc46DPOpt/options file.
Good luck, I learned a vast amount reading the forum
Old   December 25, 2013, 08:35
Ke Wu
itsme_kit is on a distinguished road
Many Thanks,
Andy.
Hi Andy
May I have some guidelines about installing openforam in mac os x mavericks
Thanks
itsme_kit is offline   Reply With Quote
Old   December 25, 2013, 08:53
Andy Lowe
Hi this is the wiki page I used.
http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2
Good luck,
Andy.
Old   December 28, 2013, 10:25
Ke Wu
Good luck,
Andy.
Hi Andy
I have followed the instruction to install OpenFoam
however, when I try to run one of cases in tutorial, those commands not find
blockMesh
icoFoam
paraFoam
Do you know what happens in my situation
Thanks
Old   December 28, 2013, 10:36
Andy Lowe
Hi, did you get any compile errors? If it compiled without errors then you need to open a new terminal and source the bashrc file in OpenFOAM/OpenFOAM-2.2.2/etc/
Andy.
Old   December 28, 2013, 10:53
Ke Wu
Andy.
yes i got compile errors
how can i fix them
Old   December 28, 2013, 10:59
Andy Lowe
Hi, find the first error then search on this forum for a solution. If you can't find a solution on the forum, then post the error on this thread along with your compile log. Someone will be able to solve the issue.
Andy.
Old   December 28, 2013, 12:34
Default Compile error for Installation/Mac OS/OpenFOAM 2.2.2
Ke Wu
Hi
I have followed every step in this instruction: http://openfoamwiki.net/index.php/In...es_and_patches
In the section of 4 Diagnosis and Problems, I found such errors which I don't know how to fix them
Probably due to these error, commands (blockMesh, icoFoam, paraFoam) can't be found when I try to run cavity case in tutorial
I attached the log file for your assistance
Many thanks
Old   December 28, 2013, 13:30
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@itsme_kit: The problem seems to be that something in the installation of Macports, XCode, GCC or standard C/C++ library did not go well.
If you try to build a small C or C++ application, you should probably get a very similar error.
Have a look into the older tutorial for OpenFOAM 2.1.x, in the respective section regarding the basic requirements: http://openfoamwiki.net/index.php/In...c_requirements
Best regards,
Bruno
___
I'll be at OFW11 in Portugal
Old   December 28, 2013, 13:42
Ke Wu
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hi Bruno
I checked MPI installation by typing mpirun -v in the terminal
I got a problem: --------------------------------------------------------------------------
No executable was specified on the mpirun command line.
Aborting.
I'm not sure what it means
Old   December 28, 2013, 13:46
Bruno Santos
Means that the MPI toolbox is not installed.
Old   December 28, 2013, 13:52
Ke Wu
Any guideline available to install MPI toolbox
No info provided in wiki
Old   December 28, 2013, 14:35
Ke Wu
MPI has been sorted it out
But still those commands can't be found
Old   January 10, 2014, 12:35
Ruben Di Battista
tidusuper91 is on a distinguished road
In the Wiki is provided how to install openmpi. Supposing you correctly installed Macports
sudo port install openmpi
Did you follow the Final Steps of the tutorial in particular the point 6? It is about openmpi (and the mpirun command).
tidusuper91 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 14:39
installation on mac os x lion achyutan OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 1 February 28, 2013 09:15
Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 22 January 21, 2013 12:51
Problem when installing Openfoam 2.0.x with mac giovaniharyadi OpenFOAM Installation 0 March 24, 2012 19:45
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 129 June 19, 2010 09:23
