OpenFOAM 2.2.2 failed in Mountain Lion
Old   January 12, 2014, 16:43
Default OpenFOAM 2.2.2 failed in Mountain Lion
Marion
cymbourne is on a distinguished road
Hi guys!
I've followed step by step this tutorial to install OpenFoam in mac (http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2) and I'm getting some errors when I try to compile it. These are the errors I get in my .log file:
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict - DSCOTCH_VERSION=6 -DSCOTCH_RELEASE=0 -DSCOTCH_PATCHLEVEL=0 dummysizes.c -o dummysizes -lz -lm -lrt
ld: library not found for -lrt
collect2: ld returned 1 exit status
make[2]: *** [dummysizes] Error 1
make[1]: *** [scotch] Error 2
make: *** [scotch] Error 2
+ make realclean
Any help will be much appreciated!
Cheers,
cymbourne is offline   Reply With Quote
Old   January 13, 2014, 16:17
Retired Super Moderator
Bruno Santos
Greetings cymbourne,
A nearly identical problem occurred back in March 2013, as shown in posts #2 and #3 on this thread: http://www.cfd-online.com/Forums/ope...tml#post412672
The problem was fixed by using the correct patch files, which are on post #4.
Therefore, the big question is: which were the exact patch files you downloaded and applied?
Best regards,
Bruno
Old   January 29, 2014, 21:29
Default different compile problems
Peter Johnston
prjohnston is on a distinguished road
I am having problems buliding OpenFOAM-2.2.2 on my mac laptop running OS-X 10.8.4. I have followed the instructions on this web site, but I get many errors. The first error that occurs is:
make CFLAGS="-O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -DSCOTCH_PTSCOTCH" CC="openmpicc" \
ptscotch.h \
ptscotchf.h \
libptscotch.dylib \
libptscotcherr.dylib \
libptscotcherrexit.dylib
openmpicc -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -DSCOTCH_PTSCOTCH -DSCOTCH_VERSION=6 -DSCOTCH_RELEASE=0 -DSCOTCH_PATCHLEVEL=0 dummysizes.c -o ptdummysizes -lz -lm
Cannot open configuration file /opt/local/share/openmpi-mp/openmpi/openmpicc-wrapper-data.txt
Error parsing data file openmpicc: Not found
make[2]: *** [ptdummysizes] Error 243
make[1]: *** [ptscotch] Error 2
make: *** [ptscotch] Error 2
I have applied all three patches and unfortunately, have no idea what is going on.
Any help would be much appreciated.
Thanks,
Peter.
prjohnston is offline   Reply With Quote
Old   February 3, 2014, 14:38
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
ptscotch.h \
ptscotchf.h \
libptscotch.dylib \
Thanks,
Peter.
It's evidently a problem with openmpi. Did you install Openmpi throught Macports? What version do you have?
Did you change the SYSTEMOPENMPI inside the etc/bashrc?
export WM_MPLIB=SYSTEMOPENMPI
rdbisme is offline   Reply With Quote
Old   February 3, 2014, 18:42
Soeren Werner
wersoe is on a distinguished road
I got the very same problems.
I think it will be caused by openmpi from Macports:
"Error: openmpi has been made obsolete by the port openmpi-default. Please install openmpi-default instead."
Means, that openmpi was not installed at all...
I will try with the suggest version, however, right now it tries to install gcc48 as a dependency...
I guess it will be best to try it again from a scratch, will do this tomorrow.
wersoe is offline   Reply With Quote
Old   February 5, 2014, 08:14
肖擎曜
kingu is on a distinguished road
Originally Posted by wersoe View Post
Hi WERSOE!
I think I have the same problem with you.
Have you solved it? How to install openmpi?
Thank you.
kingu is offline   Reply With Quote
Old   February 5, 2014, 09:52
Soeren Werner
Not yet solved...
I am at work and wont find time before the weekend I guess.
The problem is the new openmpi...
So, the solution should be either install the openmpi-default and find the location of the binaries and adjust all the neccessary config files for the OF compilation,
or,
use the openmpi from ThirdParty, however, here you have to adjust the config files too...
Keep on going...
Would be great if Bernhard or Ruben from here could help, since they originally created the patches and the wiki...
http://www.cfd-online.com/Forums/ope...ac-os-x-5.html
Best, Sören
Old   February 6, 2014, 09:32
Default Fix
Lárus Þorvaldsson
larust is on a distinguished road
Hi.
I was able to fix this problem by editing the file OpenFOAM-2.2.2/wmake/rules/darwinIntel64Gcc46/mplibMACPORTOPENMPI and changing the following lines
PINC       = -I$(MPI_ARCH_PATH)/include/openmpi
PLIBS      = -L$(MPI_ARCH_PATH)/lib -lmpi
to
PINC       = -I$(MPI_ARCH_PATH)/../include/openmpi-mp
PLIBS      = -L$(MPI_ARCH_PATH)/openmpi-mp -lmpi
larust is offline   Reply With Quote
Old   February 7, 2014, 07:25
肖擎曜
Originally Posted by larust View Post
Hi.
to
Thank you larust!
I've tried your method and a new problem occurred. Did you just follow the wiki and only changed the file?
Here's my first error.Do you know what's going on?
make[2]: openmpicc: No such file or directory
make[2]: *** [ptdummysizes] Error 1
Old   February 7, 2014, 10:41
Lárus Þorvaldsson
Right. You might also need to add a couple of symlinks to the openmpi-default installation. I added two in /opt/local/bin
sudo ln -s mpicc-openmpi-mp openmpicc
sudo ln -s mpiexec mpirun
and then I added one in /opt/local/share/openmpi-mp/openmpi
sudo ln -s mpicc-wrapper-data.txt openmpicc-wrapper-data.txt
Old   February 8, 2014, 01:33
肖擎曜
There're still errors, but I don't think it's about openmpi.
Foam::volMesh> const&) in R.o
ld: symbol(s) not found for architecture x86_64
make[3]: *** [/Users/xqy/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOpt/bin/R] Error 1
make[2]: *** [R] Error 2
Can anyone help me with this?
Old   February 8, 2014, 21:47
rdbisme's Avatar
Ruben Di Battista
Last time I checked all the symlinks were already created by macports (it was missing just the mpirun).
I think that the patches should be edited. I contact Bernhard...
Old   September 15, 2023, 01:24
No
Mumtaz1 is an unknown quantity at this point
OpenFOAM 2.2.2 encountered compatibility issues on Mountain Lion, an older macOS version. Mountain Lion, released in 2012, had limited support for modern software due to its age and 32-bit architecture. OpenFOAM, a powerful computational fluid dynamics tool, likely faced issues with the older libraries and system components on Mountain Lion. In comparison, its size and requirements exceeded what Mountain Lion could efficiently handle, causing installation or execution failures. Users faced challenges running OpenFOAM 2.2.2 smoothly on this platform. To address this, upgrading to a more recent macOS version or utilizing a more compatible Linux distribution would be advisable for better performance and compatibility.
Mumtaz1 is offline   Reply With Quote
installation, mac os x, openfoam 2.1.x
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
