Open FOAM on macos x
Old   February 1, 2014, 09:41
Default Open FOAM on macos x
Ramesh Yapalparvi
yapalparvi is on a distinguished road
Hi
I'm trying to install Openfoam 2.1 on Macos x snow leoprad 10.6.8
I followed the same steps as in the wiki page and everything worked OK. Finally when I used .Allwmake I'm getting the error message
ramesh(106). OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
/Users/ramesh
ramesh(107)cd OpenFOAM/OpenFOAM-2.1.1
ramesh(108)./Allwmake
./Allwmake: line 4: wmakeCheckPwd: command not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
yapalparvi is offline   Reply With Quote
Old   February 2, 2014, 13:49
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Originally Posted by yapalparvi View Post
Hi
/Users/ramesh
You have to source the etc/bashrc file
#Go to OpenFOAM directory
source etc/bashrc
rdbisme is offline   Reply With Quote
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
