[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch
Like Tree8Likes
Old   August 15, 2014, 00:54
Default Openfoam2.3 on Mac 10.9
  #101
Juimo Pierre
Roskiki is on a distinguished road
how to compile ThirPArty-2.3.x on mac 10.9?
how to compute in parallel ?
Roskiki is offline   Reply With Quote
Old   October 22, 2014, 06:14
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
If you installed all the Thirdparty utilities with Macports you should not need to compile it.
To test parallel computing try to run a case that uses decomposeParDict.
rdbisme is offline   Reply With Quote
Old   October 22, 2014, 13:03
rdbisme's Avatar
Ruben Di Battista
Hello everyone, I'm not getting errors in the compilation process with Gcc48 (I attached the log) but if I run any OF function (blockMesh, icoFoam on tutorials) i get segmentation fault: 11 error.
Someone can give an hint about that?
LOG: https://mega.co.nz/#!qE9zHKBT!Y_1qx4...x2gDmHmOAGayfY
(It was too big for forum limits)
(I followed these instructions because I had same issues )
PS: I'm on Yosemite
Old   October 22, 2014, 15:07
Assistant Moderator
Bernhard Gschaider
PS: I'm on Yosemite
You just recently upgraded to Yosimite but installed your MacPorts stuff before on Mavericks? Just a theory. (I think they recommend on the MacPorts-site to reinstall after an OS-update)
I usually wait a couple of weeks before upgrading my Mac OS X. It just makes life so much easier
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 22, 2014, 15:21
rdbisme's Avatar
Ruben Di Battista
Just followed the Migration guide on Macports site: basically they make you reinstall everything after the update.
Moreover it seems that on Macports they are having some troubles with libgcc. They say to have fixed it with Gcc48 and later. I try to update Macports...
Old   October 22, 2014, 15:43
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
7z? It's good
alexeym is offline   Reply With Quote
Old   October 22, 2014, 16:54
rdbisme's Avatar
Ruben Di Battista
Originally Posted by alexeym View Post
7z? It's good
Yes but the forum doesn't accept .7z files
Old   October 23, 2014, 05:26
rdbisme's Avatar
Ruben Di Battista
Ok. I confirm that after the update of libgcc and gcc48 I successfully compiled OpenFOAM on Yosemite.
As I have some sparetime I create the new Wiki page.
Thanks gschaider for the patch and the users for the support with the missing linking libraries for interFoam.
Old   October 23, 2014, 08:56
Assistant Moderator
Bernhard Gschaider
Thanks. For
a) running into the fire
b) feedback on the success (not everyone does that)
c) the intention to share your experience on the Wiki
Old   October 25, 2014, 22:03
Default swak4Foam and ThirdParty-2.3.x on mac 10.10 (Yosemite)
  #110
Juimo Pierre
1-how to install ThirdParty-2.3.x with MAcport on mac os 10.10 (Yosemite).
2- swak4foam error...
make[1]: *** [/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/fieldReport] Error 1
make: *** [fieldReport] Error 2
Making dependency list for source file funkyDoCalc.C
SOURCE=funkyDoCalc.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/simpleFunctionObjects/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/funkyDoCalc.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/simpleFunctionObjects/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/funkyDoCalc.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -L/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkyDoCalc
Undefined symbols for architecture x86_64:
"Foam:refixOSstream::writeQuoted(std::basic_stri ng<char, std::char_traits<char>, std::allocator<char> > const&, bool)", referenced from:
vtable for Foam:ebugOStream in funkyDoCalc.o
"Foam::OSstream::flags(std::_Ios_Fmtflags)", referenced from:
"Foam::fileName:perator=(std::basic_string<c har, std::char_traits<char>, std::allocator<char> > const&)", referenced from:
_main in funkyDoCalc.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make[1]: *** [/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkyDoCalc] Error 1
make: *** [funkyDoCalc] Error 2
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration. Utility funkyPythonPostproc not compiled
Making dependency list for source file funkySetBoundaryField.C
could not open file directMappedPatchBase.H for source file funkySetBoundaryField.C due to No such file or directory
SOURCE=funkySetBoundaryField.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/funkySetBoundaryField.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/funkySetBoundaryField.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -L/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkySetBoundaryField
Making dependency list for source file funkySetFields.C
could not open file directMappedFvPatch.H for source file funkySetFields.C due to No such file or directory
could not open file directMappedWallFvPatch.H for source file funkySetFields.C due to No such file or directory
could not open file directMappedPointPatch.H for source file funkySetFields.C due to No such file or directory
could not open file FixedValuePointPatchField.H for source file funkySetFields.C due to No such file or directory
could not open file ZeroGradientPointPatchField.H for source file funkySetFields.C due to No such file or directory
could not open file CalculatedPointPatchField.H for source file funkySetFields.C due to No such file or directory
SOURCE=funkySetFields.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/funkySetFields.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/funkySetFields.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -lsampling -L/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkySetFields
Making dependency list for source file funkySetLagrangianField.C
could not open file Particle.H for source file funkySetLagrangianField.C due to No such file or directory
SOURCE=funkySetLagrangianField.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/basic/lnInclude -I../../Libraries/swakLagrangianParser/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/funkySetLagrangianField.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/basic/lnInclude -I../../Libraries/swakLagrangianParser/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/funkySetLagrangianField.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -llagrangian -L/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/lib -lswakLagrangianParser -lswak4FoamParsers -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkySetLagrangianField
vtable for Foam:ebugOStream in funkySetLagrangianField.o
make[1]: *** [/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkySetLagrangianField] Error 1
make: *** [funkySetLagrangianField] Error 2
Making dependency list for source file funkyWarpMesh.C
could not open file directMappedFvPatch.H for source file funkyWarpMesh.C due to No such file or directory
could not open file directMappedWallFvPatch.H for source file funkyWarpMesh.C due to No such file or directory
could not open file directMappedPointPatch.H for source file funkyWarpMesh.C due to No such file or directory
could not open file FixedValuePointPatchField.H for source file funkyWarpMesh.C due to No such file or directory
could not open file ZeroGradientPointPatchField.H for source file funkyWarpMesh.C due to No such file or directory
could not open file CalculatedPointPatchField.H for source file funkyWarpMesh.C due to No such file or directory
SOURCE=funkyWarpMesh.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/funkyWarpMesh.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/funkyWarpMesh.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -L/Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/funkyWarpMesh
Making dependency list for source file replayTransientBC.C
SOURCE=replayTransientBC.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/cfdTools/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/cfdTools/general/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/replayTransientBC.o
g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/cfdTools/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/cfdTools/general/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib/openmpi-1.6.5 -lPstream Make/darwinIntel64GccDPOpt/replayTransientBC.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib \
-lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/root-2.3.x/platforms/darwinIntel64GccDPOpt/bin/replayTransientBC
make: Target `application' not remade because of errors.
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /Users/Mowa/OpenFOAM/swak4Foam_2.x/Libraries (most people will be fine without setting that variable)
please code.
Old   November 4, 2014, 10:45
Default installation script
  #111
Ruud Vlaming
devlaam is on a distinguished road
Hey,
Just finished the process of installing openFOAM 2.3.x on my Mac. I captured the process and put the instructions on github see:
https://github.com/devlaam/
Basically the installation should now simplify to the following procedure.
  1. Make a case sensitve partition (yes, my script refuses to run on the mac default partition)
  2. Make sure you have macports on board.
  3. Then, on a suitable directory on your case sensitve partition type:
    git clone git://github.com/devlaam/openfoam-mac-install.git
    cd openfoam-mac-install
    sudo ./prepare-openfoam-2.3.x install
    ./install-openfoam-2.3.x install
    ./install-openfoam-2.3.x compile
And your good to go! [If you type the commands without these arguments, you get help in more detail.]
btw: this is the first release, so probably there is room for improvement. Not tested on Yosemite yet.
Have fun.
Ruud Vlaming.
makaveli_lcf likes this.
devlaam is offline   Reply With Quote
Old   November 5, 2014, 04:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by devlaam View Post
Hey,
Have fun.
Ruud Vlaming.
Nice. I'm sure that as soon as you get positive feedback you will add it to the relevant page on the Wiki, right?
Old   November 5, 2014, 11:23
Ruud Vlaming
sure, no prob.
Old   December 4, 2014, 06:21
serviet is on a distinguished road
Finally working on yosemite with gcc4.8 Thanks gschaider!
after a lot of missing library error messages, just a little comment to add :
When setting the environment paths, i still saw referencies to the Thirdparty directory... In fact the variable $WM_USE_MACPORT was not set properly in etc/config/settings.sh due to the command 'which' which was returning (on my system) :
which -s port  ; echo $?
/opt/local/bin/port
1
and not 0. Changing the test l.200 of etc/config/settings.sh
if [ $? -eq "1" -a -d '/opt/local/etc/macports' ]
did the trick. For those who have linking problem, check the differents env variable with command 'printenv'.
serviet is offline   Reply With Quote
Old   December 4, 2014, 16:02
Assistant Moderator
Bernhard Gschaider
/opt/local/bin/port
1
That is strange. The 1-thing. Rechecked and my Maverick-System always returned 0 (on bash and zsh). I assume you use bash. Which version does "bash -version" report?
Ah. The "joys" of shell-scripting
Old   December 5, 2014, 04:21
yes I guess 3.2.53
the 1 return code stands for the number of arguments which failed, and in my case it seems the which command just doesnt get the -s option...
which port  ; echo $?
/opt/local/bin/port
0
Curious to know if it's the case for other people. btw thank you all again, OF works great!
Old   December 5, 2014, 07:04
Alexey Matveichev
Hi, here's the output on my Yosemite:
myself at daphne in ~$ which -s brew ; echo $?
0
myself at daphne in ~$ which -s port ; echo $?
1
myself at daphne in ~$ sw_vers
ProductName:	Mac OS X
ProductVersion:	10.10.1
BuildVersion:	14B25
myself at daphne in ~$ bash --version
GNU bash, version 3.2.53(1)-release (x86_64-apple-darwin14)
Copyright (C) 2007 Free Software Foundation, Inc.
myself at daphne in ~$ type which
which is hashed (/usr/bin/which)
Old   December 9, 2014, 07:23
Assistant Moderator
Bernhard Gschaider
0
1
BuildVersion:	14B25
Difference between port and brew is? One is installed, the other one isn't?
Old   December 9, 2014, 07:27
Alexey Matveichev
Yes, brew is installed, port is not. I.e. it's documented behavior of the -s flag:
DESCRIPTION
     -s      No output, just return 0 if any of the executables are found, or 1 if none
             are found.
Old   December 9, 2014, 07:54
Assistant Moderator
Bernhard Gschaider
DESCRIPTION
             are found.
I was a bit confused because I mixed you up with the other guy who HAD port installed
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
