-   OpenFOAM Installation on Windows, Mac and other Unsupported Platforms (http://www.cfd-online.com/Forums/openfoam-installation-windows-mac/)
-   -   generating .foam or .OpenFOAM file with openfoam installed on windows 7 (http://www.cfd-online.com/Forums/openfoam-installation-windows-mac/131418-generating-foam-openfoam-file-openfoam-installed-windows-7-a.html)
vasava March 14, 2014 09:26
I have managed to install openfoam2.1.x on windows 7. The tutorial example runs fine without any errors. Now I want to know how I could visualize the results on windows.
I already have paraview installed. I installed separately so it 'paraFoam' command does not work. Also the 'touch' command is also not working as I am in windows.
Anyone??
wyldckat March 15, 2014 06:32
Quick answer: On Windows, you can use this command:
echo. > case.foam
vasava March 17, 2014 02:25
Thanks I will try that.
vasava March 20, 2014 05:39
echo. > case.foam
This worked fine. Thank you.
uuivw May 22, 2014 10:35
echo. > case.foam
I just try it , and it let me select an application to open the file ,but paraview remind me that "Got unknown argument ",what's wrong~~
wyldckat May 24, 2014 02:57
Hi Liaoning,
If you were to run this command:
paraview -help
in the command line, it should give you a list of options that can be used from the command line. In other words, the way you've done for associating ParaView to the file format ".foam", assumes that it could be launched like this:
paraview file.foam
Problem is that ParaView needs an additional argument for it to work, like this:
paraview --data=file.foam
Since it's a bit complicated to explain how this can now be fixed, it's easier to suggest the following steps:
  1. Start ParaView from the Windows Start Menu.
  2. In the command line where you are working with the case, run:
    explorer .
    Notice the space and dot at the end, which will tell Windows Explorer to open in the current folder where the command line is working on.
  3. In Windows Explorer, select the full address of the folder and copy it.
  4. Go to ParaView, menu "File -> Open", paste the address in the file name edit box and press Enter. Then select the ".foam" file and click "Open".
Best regards,
Bruno
