Home > Forums > OpenFOAM Installation on Windows, Mac and other Unsupported Platforms
SparceImage v1.7.x Issue on MAC OS X
Old   August 12, 2014, 12:07
Default SparceImage v1.7.x Issue on MAC OS X
Remi Carmi
rcarmi is on a distinguished road
I tried to compile OpenFOAM v1.7.x that I downloaded here
http://sourceforge.net/projects/macopenfoam/files/
After downloading it I copied it in my main directory ~/carmi.
I mounted the disk (double click on it).
I use the following command in my terminal :
ln -sf /Volumes/Mac-OF-1.7.x OpenFOAM
cd OpenFOAM
ln -sf ~/Documents/OF-User `whoami`-1.7.x
I edited my profile : by adding
source . ~/OpenFOAM/OpenFOAM-2.0.x/etc/bashrc
I close the terminal app
Nothing happens.
I try then to do :
cd OpenFOAM/OpenFOAM-1.7.x/
wcleanAll
source ./etc/bashrc
then
./Allwmake
Did not work. I try to recompile a second time and still this error at the end
"make: Target `application' not remade because of errors."
The first error in the log file is :
"ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make[2]: *** [/Users/Carmi/OpenFOAM/OpenFOAM-1.7.x/applications/bin/darwinIntel64DPOpt/compressibleInterFoam] Error 1"
The output is in the txt file.
Please help!
Thank you a lot
rcarmi is offline   Reply With Quote
Old   August 12, 2014, 14:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by rcarmi View Post
cd OpenFOAM
Nothing happens.
I try then to do :
wcleanAll
source ./etc/bashrc
then
./Allwmake
Please help!
Thank you a lot
Do you really need 1.7? I'd be very surprised if that image still works as it was probably done for a version of Mac OS X that is 2 or 3 generations away.
Plus: you're mixing the 1.7.x and the 2.0.x-version in the commands you use
The latest image of a foam-version hat I know of (there may be others) is found at https://sourceforge.net/projects/ope...am-extend-3.1/ (but I haven't used it. I compile my Foam myself)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 13, 2014, 12:19
Remi Carmi
Thanks for your quick response.
I know that there are more recent versions. I am currently using (and it works just fine) the OF.2.3
I need the version 1.7 because I am trying to use IHFOAM and it encounters some errors on OF.2.3.
For the typo in the commands, it is a copy/paste mistake. I meant 1.7.x.
Thanks again
Old   August 13, 2014, 22:39
Default Issue with OF.2.2.2
Remi Carmi
I switch to version 2.2.2 which works fine with IHFOAM.
I am trying to compile a parallel example but it does not work.
The reason is I have some "could not open file" errors when I compile OF2.2.2
wmake libso mpi
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file UOPwrite.C
Making dependency list for source file UIPread.C
Making dependency list for source file UPstream.C
Making dependency list for source file PstreamGlobals.C
could not open file omp.h for source file UIPread.C
could not open file omp.h for source file UOPwrite.C
could not open file omp.h for source file UPstream.C
could not open file omp.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file UIPread.C
could not open file ompi/mpi/cxx/constants.h for source file UIPread.C
could not open file ompi/mpi/cxx/functions.h for source file UIPread.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file UPstream.C
could not open file ompi/mpi/cxx/datatype.h for source file UIPread.C
could not open file ompi/mpi/cxx/constants.h for source file UPstream.C
could not open file ompi/mpi/cxx/functions.h for source file UPstream.C
could not open file ompi/mpi/cxx/datatype.h for source file UPstream.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/constants.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/functions.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/datatype.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/constants.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/functions.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/datatype.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/exception.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/exception.h for source file UPstream.C
could not open file ompi/mpi/cxx/op.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/exception.h for source file UIPread.C
could not open file ompi/mpi/cxx/op.h for source file UPstream.C
could not open file ompi/mpi/cxx/status.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/op.h for source file UIPread.C
could not open file ompi/mpi/cxx/request.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/status.h for source file UIPread.C
could not open file ompi/mpi/cxx/status.h for source file UPstream.C
could not open file ompi/mpi/cxx/group.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/request.h for source file UIPread.C
could not open file ompi/mpi/cxx/request.h for source file UPstream.C
could not open file ompi/mpi/cxx/comm.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/win.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/group.h for source file UPstream.C
could not open file ompi/mpi/cxx/file.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/comm.h for source file UPstream.C
could not open file ompi/mpi/cxx/errhandler.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/win.h for source file UPstream.C
could not open file ompi/mpi/cxx/intracomm.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/file.h for source file UPstream.C
could not open file ompi/mpi/cxx/topology.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/errhandler.h for source file UPstream.C
could not open file ompi/mpi/cxx/intercomm.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/intracomm.h for source file UPstream.C
could not open file ompi/mpi/cxx/info.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/topology.h for source file UPstream.C
could not open file ompi/mpi/cxx/intercomm.h for source file UPstream.C
could not open file ompi/mpi/cxx/info.h for source file UPstream.C
could not open file ompi/mpi/cxx/group.h for source file UIPread.C
could not open file ompi/mpi/cxx/comm.h for source file UIPread.C
could not open file ompi/mpi/cxx/win.h for source file UIPread.C
could not open file ompi/mpi/cxx/file.h for source file UIPread.C
could not open file ompi/mpi/cxx/exception.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/errhandler.h for source file UIPread.C
could not open file ompi/mpi/cxx/op.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/status.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/request.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/intracomm.h for source file UIPread.C
could not open file ompi/mpi/cxx/group.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/topology.h for source file UIPread.C
could not open file ompi/mpi/cxx/comm.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/win.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/intercomm.h for source file UIPread.C
could not open file ompi/mpi/cxx/info.h for source file UIPread.C
could not open file ompi/mpi/cxx/file.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/errhandler.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/intracomm.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/topology.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/intercomm.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/info.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pop_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pop_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/functions_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/pop_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/request_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/comm_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/topology_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/group_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/functions_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/op_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/request_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/comm_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/status_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/topology_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/info_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/win_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/file_inln.h for source file UPstream.C
could not open file ompi/mpi/cxx/group_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/op_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/status_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/functions_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/info_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/request_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/win_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/comm_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pop_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/file_inln.h for source file UIPread.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/topology_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/group_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/op_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/status_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/info_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/win_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/file_inln.h for source file PstreamGlobals.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/functions_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/request_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/comm_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/topology_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/group_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/op_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/status_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/info_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/win_inln.h for source file UOPwrite.C
could not open file ompi/mpi/cxx/file_inln.h for source file UOPwrite.C
And further :
wmake libso ptscotchDecomp
Making dependency list for source file ptscotchDecomp.C
could not open file omp.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/constants.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/functions.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/datatype.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/exception.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/op.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/status.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/request.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/group.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/comm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/win.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/file.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/errhandler.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intracomm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/topology.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intercomm.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/info.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pop_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pgroup_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/pstatus_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/prequest_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/datatype_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/functions_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/request_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/comm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intracomm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/topology_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/intercomm_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/group_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/op_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/errhandler_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/status_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/info_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/win_inln.h for source file ptscotchDecomp.C
could not open file ompi/mpi/cxx/file_inln.h for source file ptscotchDecomp.C
could not open file ptscotch.h for source file ptscotchDecomp.C
SOURCE=ptscotchDecomp.C ; g++-mp-4.6 -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/local/include -I/include -I/Users/Carmi/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-system -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/Users/Carmi/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/Users/Carmi/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOptSYSTEMOPENMPI/ptscotchDecomp.o
ptscotchDecomp.C: In member function 'Foam::label Foam:tscotchDecomp::decompose(const Foam::fileName&, int, const int*, int, const int*, const scalarField&, Foam::List<int>&) const':
ptscotchDecomp.C:551:39: warning: use of old-style cast [-Wold-style-cast]
ld: warning: directory not found for option '-L/Users/Carmi/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOptSYSTEMOPENMPI/lib'
ld: warning: directory not found for option '-L/lib'
ld: library not found for -lptscotch
make: *** [/Users/Carmi/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-system/libptscotchDecomp.dylib] Error 1
+ wmake libso decompositionMethods
This is the function I try to use to parallel.
Can somebody help me fix that?
Thank you a lot.
I tried increasing the number ulimit but and recompile the error persisted.
Thanks
Remi
Old   August 14, 2014, 06:42
Assistant Moderator
Bernhard Gschaider
Thank you a lot.
Thanks
Remi
Which steps from http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2 did you already successfully apply? Or which instructions/patches are you using?
Thread Tools
Trackbacks are On
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 17:50
Is it a good idea to use OpenFoam on a Mac (OS 10.7.5) or on Windows7? bzz77 OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 4 November 21, 2012 18:06
2.0.x on Mac OSX niklas OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 74 March 28, 2012 16:46
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
OpenFOAM-1.7.x MAC OS X foamToTecplot360 issue haewon OpenFOAM Installation 0 November 14, 2010 03:05
