Having issues installing some features of OPENFOAM on my 32bit OS
My laptop is a 32bits as opposed to 64bits some of the features in OPENFOAM requires for installation.
Any possible solution on how to install this? Thanks |
Greetings orobome and welcome to the forum!
You are going to have to be more specific, because the limitation is not in the machine being 32 or 64-bit. The limitation might be dependant on the Operating System you are currently using. For example, both 32 and 64-bit Deb packages are provided for installing OpenFOAM 2.3.0 on Ubuntu 12.04 to 13.10: http://www.openfoam.org/download/ubuntu.php Best regards, Bruno |
openfoam installation in windows 7
Thank you so much whyc!
my OS is windows 7. What next do i do? The very best of regards! |
error message when installing openfoam 1.7.0
i got this error message when i tried installing openfoam on my windows 32bits OS:"acrchive corrupt"
I downloaded the openfoam 1.7.0 from site suggested by jlight: Http://sourceforge.net/projects/openfoam-170/ Please,I really do a solution. Best of regards! |
re:error message in installing openfoam 1.7.0
I got this error message -"archive corrupt"-when installing openfoam 1.7.0 on my 32bits windows OS.
Any with an idea Thanks! |
Hi orobome,
If the file is corrupt, then try downloading the file once again, because the download might have failed midway and you might have gotten an incomplete package. There is a page on the (unofficial) wiki that has a list of known OpenFOAM ports for Windows: http://openfoamwiki.net/index.php/Windows From there, and given that you're using a 32-bit Windows, I suggest you try out blueCFD-SingleCode 2.1-2: https://code.google.com/p/bluecfd-singlecore/ Disclaimer: I'm the guy responsible for blueCFD-SingleCore. Best regards, Bruno |
Thanks a million;I will try it
error during installing the openfoam for windows7 32 bit
hello
I can't install the OpenFoam 1.7.0 for windows7 32bit. there is an error in cmd.exe (like "installation failed" after give the command "cd C:\Program Files\MPICH2\bin" ) and no internal and external files ...like errors a got. please help thanks in advance reply as soon as possible |
