Error with IHFOAM version OF2300 in Mac
Dear Colleagues,
I have compiled IHFOAM for OpenFOAM 2.3.0 on my MAC (yosemite) and it works. However, I have problem compiling IHFOAM for OpenFOAM 2.3.x, the "genAbs" is ok, but for "solvers" IHFOAM throw the following error: Code:
Making dependency list for source file ihFoam.C |
Error with mac
Hi Andres,
Have you not encountered any issue when you compile IHFOAM for OF2.3.0?? I have errors and do not know why. Do you have an idea for this? The following errors occur in my case. In file included from /Users/totalart/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.H:394: /Users/totalart/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C:461:10: warning: reference cannot be bound to dereferenced null pointer in well-defined C++ code; pointer may be assumed to always convert to true [-Wundefined-bool-conversion] && &mapper.directAddressing() ~~ ^~~~~~~~~~~~~~~~~~~~~~~~~ /Users/totalart/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/FieldMapper.H:71:35: note: 'directAddressing' returns a reference virtual const labelUList& directAddressing() const ^ ... 2.3.0/src/OpenFOAM/lnInclude/Field.C:496:14: warning: reference cannot be bound to dereferenced null pointer in well-defined C++ code; pointer may be assumed to always convert to true [-Wundefined-bool-conversion] && &mapper.directAddressing() ~~ ^~~~~~~~~~~~~~~~~~~~~~~~~ /Users/totalart/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C:247:22: note: in instantiation of member function 'Foam::Field<double>::autoMap' requested here Field<Type>::autoMap(mapper); ^ IH_Waves_InletAlpha/IH_Waves_InletAlphaFvPatchScalarField.C:60:1: note: in instantiation of member function 'Foam::fvPatchField<double>::autoMap' requested here IH_Waves_InletAlphaFvPatchScalarField ^ /Users/totalart/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/FieldMapper.H:71:35: note: 'directAddressing' returns a reference virtual const labelUList& directAddressing() const ^ 9 warnings and 7 errors generated. make: *** [Make/darwinIntel64ClangDPOpt/IH_Waves_InletAlphaFvPatchScalarField.o] Error 1 \n\nWave generation boundary conditions compilation failed Best regards, Youngkook |
Hi, I'm sorry for not answering your question. Instead I have alternative solution. You can run on your Mac much recent version of OpenFOAM, OpenFOAM 1612+ by OpenCFD (easy install via docker http://openfoam.com/download/install-binary-mac.php). Inside the docker, you may either compile IHcantabria models yourself, or you may use the boundary conditions directly as they have been implemented into the main code (http://www.openfoam.com/version-v161...conditions.php).
Hi all,
@totalart Unfortunately you did not post the error itself. In your output only warnings caused by old codebase are present (modern compilers optimise-out null-checks for reference addresses). So either you can use OpenFOAM+ as matejfor suggested, or, if you really-really need native execution, please post your full build log (and it would be easier, if you describe, how you install OpenFOAM itself). |
