Installing OF 1.6 on Mac OS X
Old   July 29, 2009, 19:58
Default Installing OF 1.6 on Mac OS X
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Hi!
I managed to compile OF 1.6 on my MacBook. The necessary patches and some (very short) instructions can be found at:
http://openfoamwiki.net/index.php/Ho...enFOAM_v16_Mac
IMHO the instructions are sufficient for somebody who has already compiled OF (preferably on a Mac) but for someone who has never compiled OF they may be hard to understand. I therefor encourage everyone who finds an error (typo or otherwise) on that page or who finds the instructions on the page too short to extend the page. Maybe it will grow into something that is usable for everyone
Bernhard
gschaider is offline   Reply With Quote
Old   July 29, 2009, 22:35
Pierre-Olivier Dallaire
podallaire is on a distinguished road
cool, will give it a try
Thanks
PO
podallaire is offline   Reply With Quote
Old   July 30, 2009, 04:54
Assistant Moderator
Bernhard Gschaider
With it you mean augmenting the Wiki-page, I assume? Great. But first try the patches
Old   July 30, 2009, 07:41
Hi !
The compiling was successful under 32 bit. I'm planning to try 64 bit later today. I might try ParaView later but I'm planning to stick to Takuya's reader.
For sure I will contribute to the wiki page !
Thanks
PO
Old   July 30, 2009, 08:31
Assistant Moderator
Bernhard Gschaider
In the vanilla compilation fails with an error message that the Carbon-Framework is not supported in 64 bit. I went to $Pareview_Dir and tried to change the configuration manually with "ccmake ." to use Cocoa instead and compile with make, but it seems like it still tries to compile with Carbon.
So I'm afraid Takuya's reader won't work in 64bit, too.
Looking forward to it
Old   July 30, 2009, 08:34
Did you recompile QT with Cocoa 64 bit ? That's the key !
Old   July 30, 2009, 09:06
Hi Bernhard,
for darwinIntel64, I think the patches will need very minor modifications for
the "if defined darwinPpc || defined darwinIntel" statements.
Regards,
PO
Old   July 30, 2009, 09:14
Assistant Moderator
Bernhard Gschaider
No. I don't think so (I think I'm living off a binary downloaded from Trolltech)
Old   July 30, 2009, 09:59
Assistant Moderator
Bernhard Gschaider
That would be in the ThirdParty-patch wouldn't it? I checked and for some reason it compiles anyway. Obviously because in the meantime there is a /usr/include/malloc.h (a symbolic link to /usr/include/sys/malloc.h which was what this condition was working around)
But WHAT I noticed during checking is that for 64 bit in wmake/Makefile the extension for shared libs is NOT set to dylib. But this should be only of cosmetic importance
Old   August 2, 2009, 05:43
Default Patches for OpenFOAM 1.6 on OSX
Andrew Ryan
andrewryan is on a distinguished road
Hi all
I found this instructions [1] however I'm unable to download the patches linked there (I just get some html files), does anybody here have this patches? Would be great if you could post them again.
[1] http://openfoamwiki.net/index.php/Ho...enFOAM_v16_Mac
andrewryan is offline   Reply With Quote
Old   August 2, 2009, 08:01
Use Firefox instead of Safari to download the files
Cheers
PO
Old   August 3, 2009, 10:25
Assistant Moderator
Bernhard Gschaider
I never noticed that problem (it is more often that I upload than download ). Does it happen for all files on the Wiki?
Old   August 3, 2009, 11:13
Andrew Ryan
I tried to compile OF as described in the wiki. I could apply the patches by using patch -p1 < patchfile. However it still didn't compile. I posted the build log [1] could anybody have a look at it? Also it complained that it could not find malloc.h which is in /usr/include/sys. As a workaround i created a symlink in /usr/include for malloc.h.
[1] http://emerging-patterns.com/tmp/compile.log
Old   August 3, 2009, 11:53
Bernhard,
I have applied minor modifs to your patches regarding the darwinIntel64 arch / should I send it you via email for your review ? We could add those files on the Wiki
Andrew - those modifs should help you
Thanks
PO
Old   August 3, 2009, 13:02
Assistant Moderator
Bernhard Gschaider
The line
could not open file PrimitivePatch.H for source file db/regIOobject/regIOobject.C
leads me to the question: you're compiling OF on a case-sensitive-filesystem, are you? Got to $FOAM_SRC/OpenFOAM/lnInclude and chack if there is a primitivePatch.H AND a PrimitivePatch.H. If not got back to the start (create a disk-image or a partition with a case-sensitve file-system and do the compilation there)
Bernhard
Old   August 3, 2009, 13:03
Assistant Moderator
Bernhard Gschaider
Bernhard,
Yes please. Send them to me
They solve the malloc.h-problem, right?
Old   August 3, 2009, 13:12
just sent an email / yes, no malloc problem
Old   August 3, 2009, 13:38
Andrew Ryan
@gschaider: I was asking myself that too and checked it:
macbook:~ nils$ cd /Users/nils/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/
macbook:lnInclude nils$ ls [pP]rimitivePatch.H
PrimitivePatch.H primitivePatch.H
Otherwise I would already get trouble when trying to expand the archive, right? I also noticed the "could not open file" errors, but don't have an idea why they appear..
@podallaire What else problems does your new patch fix?
Old   August 3, 2009, 15:59
... just minor details which replicate the behavior of the patch for 32 bit (darwinIntel) for the 64 bit (darwinIntel64)
Old   August 3, 2009, 18:00
Assistant Moderator
Bernhard Gschaider
OK. The case-sensitivity is not the problem
No. when untarring PrimitivePatch.H would overwrite primitivePatch.H (or the other way round. whoever comes last)
Either because they are not there or some script 'thinks' they are not there . Check with
find $FOAM_SRC -name missingFile.C
whether these files are there. Maybe something happened during untarring
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 05:06
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 12:54
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Mac Simple Install Request or Processing Assistance Help sjohnson OpenFOAM Installation 4 December 12, 2008 07:46
MAC + SOLA for free surface T Main CFD Forum 1 April 11, 2001 13:43
