openfoam output files
Hi everyone! I am just installing OpenFOAM to try out, and I have a very basic question for the forum at large.
I've installed openfoam-mswin and I am going through the tutorials. I go to the tutorial directory and type "blockMesh" and "icoFoam" and they both report no errors. But when I try to load the results into ParaView, it wants a .openFOAM file, and I don't have any! I've searched my hard drive, and there is nothing. Since I have never used openFOAM before, I have no idea what is supposed to happen, but apparently the tutorial and my computer don't agree about what I am supposed to get out of this. So, my questions for the forum: 1. What files are generated for you when you use openFOAM? 2. Is there a way to force a .openFOAM file to be created? Something to tack on at the command line? 3. Do I need to run something before I start meshing around? Thanks, everyone! |
Hi!
I have never used the windows version, but in (most) lunix machines I had to recompile ParaView and the PV3FoamReader, as suggested in the README. Is there maybe a .foam file? And is it perhaps possible to convert the OF results into VTK format (with foamToVTK) and open the VTK file in ParaView? Sorry I can't be of more help, hope this gets you on your way a bit. |
Greetings kjmartin,
With openfoam-mswin things get a little bit different... Your question has already been posed and answered starting here :) Best regards, Bruno Santos |
Greetings shirazbj,
It's possible if you setup an MSys environment and make a few tweaks to the OpenFOAM scripts and you can have a new Linux experience in Windows ;). But in straight forward Windows command line, you can use: Code:
echo. > case.OpenFOAM Nonetheless, things might change a bit if there are multiple regions, like in chtMultiRegionFoam. Best regards, Bruno Santos |
