Home > Forums > OpenFOAM Installation on Windows, Mac and other Unsupported Platforms
Patches for OpenFOAM 1.7 on MacOS X
Old   September 14, 2010, 07:47
Assistant Moderator
Bernhard Gschaider
Originally Posted by JanL View Post
Hi Bernhard,
you were right! There is only the file pointHit.H and not PoinHit.H!
I'm a bit confused here... My Mac OS system is case-insensitive but I created a case-sensitive image and untarred the files within this image! Is there anything I have to consider for creating such an case-sensitive image in a case-insensitive system/environment or maybe any typical mistakes I could do working with such an image?
I guess I'll try to create a new image and start from the beginning again!?
Thanks for your help!!!
If the image is case-sensitve (and you tested that if I remember it correctly) and you untarred directly onto it all the files should be there. No additional requirements that I know of
Old   September 14, 2010, 13:00
Jan Löhrmann
JanL is on a distinguished road
I just untarred the OF- and Thirdparty-file again on the case-sensitive image and now it seems that the files are complete (e.g. there is now a PointHit.H and a pointHit.H file!). So I patched everything again and copied the files bashrc and settings.sh, which I previously changed from the old directory in the new one and ran ./Allwmake.
At first it looked good and no errors (at least I didnt spot any) were shown until:
Done ThirdParty Allwmake
Afterwards there came up several warnings of this style:
IPread.C:67:51: warning: use of old-style cast
And later on there were a whole bunch of files which could not been opened:
could not open file polyPatch.H for source file db/regIOobject/regIOobject.C
could not open file labelPair.H for source file db/regIOobject/regIOobject.C
could not open file boundBox.H for source file db/regIOobject/regIOobject.C
could not open file pointZoneMesh.H for source file db/regIOobject/regIOobject.C
could not open file faceZoneMesh.H for source file db/regIOobject/regIOobject.C
could not open file cellZoneMesh.H for source file db/regIOobject/regIOobject.C
It keeps on going like this for quite a while!
It ends like this:
make: Target `application' not remade because of errors.
I checked if those missing files exist and they do!
Any idea what could have gone wrong?
I tried the foamInstallationTest and the result is this (maybe it helps to find the error!?)
Checking basic setup...
Shell: bash
Host: jan-lohrmanns-imac.local
FATAL ERROR: Incompatible operating system "Darwin".
OpenFOAM 1.7.1 is currently
available for Linux and SunOS only.
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /Volumes/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /Volumes/OpenFOAM/janlohrmann-1.7.1 yes no
$WM_THIRD_PARTY_DIR /Volumes/OpenFOAM/ThirdParty-1.7.1 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /Volumes/OpenFOAM/OpenFOAM-1.7.1 yes yes yes
$FOAM_APPBIN .../applications/bin/darwinIntel64DPOpt yes yes yes
$FOAM_SITE_APPBIN ...AM/site/1.7.1/bin/darwinIntel64DPOpt no no
$FOAM_USER_APPBIN .../applications/bin/darwinIntel64DPOpt no no
$WM_DIR /Volumes/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...penFOAM-1.7.1/lib/darwinIntel64DPOpt yes yes yes
$FOAM_SITE_LIBBIN ...AM/site/1.7.1/lib/darwinIntel64DPOpt no no
$FOAM_USER_LIBBIN ...ohrmann-1.7.1/lib/darwinIntel64DPOpt no no
$MPI_ARCH_PATH ...latforms/darwinIntel64/openmpi-1.4.1 yes yes yes
Third party software
Software Version Location
gcc 4.5.1 /opt/local/bin/gcc
gzip 1.3.12 /usr/bin/gzip
/Volumes/OpenFOAM/OpenFOAM-1.7.1/bin/foamInstallationTest: line 267: --version: command not found
gtar
icoFoam 1.7.1 ...FOAM-1.7.1/applications/bin/darwinIntel64DPOpt/icoFoam
Summary
The system test has evoked 1 fatal error(s).
Critical systems ok.
*** Review the output for warning messages and consult
*** the installation guide for trouble shooting.
done.
I tried again ./Allwmake and spotted the following warnings, which might be relevant!?
/usr/include/X11/Xlib.h:501:9: error: reference to 'Time' is ambiguous
/usr/include/X11/X.h:82:23: error: candidates are: typedef long unsigned int Time
/Volumes/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Time.H:71:1: error: class Foam::Time
and:
make[3]: *** [Make/darwinIntel64DPOpt/tecplotWriter.o] Error 1
make[2]: *** [foamToTecplot360] Error 2
make[1]: *** [dataConversion] Error 2
I really don't know where the error might be or what it might cause! Do these quotes help anybody to find the problem?
Thanks very much for your support!
JanL is offline   Reply With Quote
Old   September 15, 2010, 22:59
paka is on a distinguished road
I try really hard to find any instruction on how to install OpenFOAM on mac, but despite my best intentions, I cannot find the right information.
Could anyone kindly post what steps are required to follow in order to have OpenFOAM-1.7 up and running on Mac Snow Leopard machine?
Thank you!
paka is offline   Reply With Quote
Old   September 16, 2010, 00:13
Chris Butler
chrisb is on a distinguished road
Thank you!
Try this:
http://chrisjbutler.wordpress.com/20...for-os-x-10-6/
Chris Butler
chrisb is offline   Reply With Quote
Old   September 16, 2010, 18:01
Thanks a lot, clear guide. However as I compile, it keeps going for about 15 minutes then it quits with following error
In file included from /Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.H:120:0,
from /Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/time.h:50,
from /usr/include/wchar.h:113,
from /opt/local/include/gcc45/c++/cwchar:47,
from /opt/local/include/gcc45/c++/bits/postypes.h:42,
from /opt/local/include/gcc45/c++/bits/char_traits.h:42,
from /opt/local/include/gcc45/c++/string:42,
from /Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/string.H:51,
from /Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/stringList.H:35,
from /Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/argList.H:73,
from mixtureAdiabaticFlameT.C:33:
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C: In constructor 'Foam::NamedEnum<Enum, nEnum>::NamedEnum()':
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C:34:18: error: template argument 3 is invalid
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C:34:19: error: expected '{' before '(' token
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C: At global scope:
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C:34:20: error: expected unqualified-id before numeric constant
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/NamedEnum.C:34:20: error: expected ')' before numeric constant
/Users/user/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/token.H:386:25: warning: inline function 'void Foam::token:perator=(int*)' used but never defined
make[2]: *** [Make/darwinIntel64DPOpt/mixtureAdiabaticFlameT.o] Error 1
make[2]: Target `/Users/user/OpenFOAM/OpenFOAM-1.7.x/applications/bin/darwinIntel64DPOpt/mixtureAdiabaticFlameT' not remade because of errors.
make[1]: *** [mixtureAdiabaticFlameT] Error 2
make[1]: Target `application' not remade because of errors.
Trying to fix it, additionally, in OpenFOAM-1.7-Mac.patch I changed all the required entries to gcc-mp-4.5, but error still persists.
$FOAM_APPBIN is empty.
Any tips?
Thanks,
P
Old   September 16, 2010, 19:08
Chris Butler
I am not that great (yet) with the errors. I have two suggestions:
Try with another build of OpenFOAM:
To get the latest head from the git repo:
git reset
git pull $OF_GIT_ADDRESS
Then re-apply the patch
OR to get the 1.7.1 build
git reset
git checkout -b master version-1.7.1
Then re apply the patch.
Make sure your OF directory and Third party directory version names match i.e. 1.7.1 or 1.7.x.
Try with another compiler:
Perhaps try gcc4.4 or gcc4.3.
I hope someone else will be more helpful!
Cheers,
Chris Butler
Old   September 16, 2010, 23:07
Thanks a lot for a prompt reply!
The thing was, somehow the disk image did mount the right way and actually I used non-case dependent OpenFOAM/ folder which I created earlier. After mounting the partition in the right way compile process moved forward.
However, I still have one question. As the compile process ended it finished with the following output message:
I'm not sure how to interpret it. Any help in this matter?
Thanks,
P
Old   September 16, 2010, 23:09
BTW. $FOAM_BINAPP points to:
and the folder lists bunch of different apps, so at least in some part applications folder was created.
Old   September 17, 2010, 05:11
Assistant Moderator
Bernhard Gschaider
Thanks,
P
You'll have to look up a bit in the logfile (I recommend always compiling with './Allwmake 2>&1 | tee compile.log' as probably your terminal will be to short). Probably the tecplot-converter and the PV3Reader-plugin didn't get compiled (but the rest was)
Old   September 17, 2010, 10:16
Jan Löhrmann
really really sorry to bother you guys but does anyone have an idea what might have been the problem while compiling OF, which I have tried to describe in my post from the 14.09. (7pm)? I'd extremely appreciate any help, as I don't have any clue!!!
PS: In the link which Chris uploaded I've seen the following command:
git clone git://github.com/OpenCFD/OpenFOAM-1.7.x.git
Is that necessary for OF to work? In that case it might be my problem, as I haven't done that so far! An is the command the same if you use OF-1.7.1?
Again: Thanks for your support!!!
Old   September 17, 2010, 19:00
Assistant Moderator
Bernhard Gschaider
Seems OK to me (foamInstallationTest finds icoFoam). The tecPlot-converter doesn't compile on Mac OS
No. Its just another way to get the sources. Either you do that or you use a tar of the release
Old   September 17, 2010, 19:07
Jan,
Follow post from the Chris blog. It is simple and clear description of the whole installation process.
Bernard, thanks for the tip. Right now as much as I had time to test things distribution is up and running.
Best,
K
Old   September 17, 2010, 20:17
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
Hi Bernhard, I'm sorry I can't help you guys out more, but since I can't get access to a Mac, my hands are tied
Nonetheless, I know someone who probably has already fixed that issue with tecPlot: Richard Smith at Symscape has patches for OpenFOAM 1.7.x, for building it for both Windows (cross-compiling) and Mac (compiling) - http://www.symscape.com/openfoam-1-7...windows-64-mpi
edit: FreeFOAM should also have this issue solved, but it's a bit harder to adapt from it
Best regards,
Bruno
PS - FYI: I've studied these patches (at blueCAPE ) and created modified patches for cross-compiling OpenFOAM in Linux for Windows, but also including most of OpenFOAM's Third Party software, and also improving on top of Symscape's patches
Old   September 20, 2010, 11:40
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks for the hint, Bruno.
Only did a brief attempt to fix the tecplot-stuff but as I don't use TecPlot myself and nobody every complained I didn't spend too much time on it. I'll have a look at the patches
Old   September 21, 2010, 04:08
Just going through OpenFOAM tutorials I noticed one of the solvers did not compile.
I tried to compile it separately and at the end all solvers as a whole, all is fine except interFoam (and Tecplot, but I don't need that one). Any tip regarding that?
Thanks!
Old   September 21, 2010, 07:10
Bruno Santos
Greetings Paka,
The inter*Foam solvers seem to be missing an option:
-linterfaceProperties
Edit the files Make/options in each solver's source code folder and add it to EXE_LIBS.
Best regards,
Bruno
Old   September 21, 2010, 13:17
Babak
babak55 is on a distinguished road
Hi All,
Does anybody knows for running OpenFOAM 1.7 on MacBook it requires OS X snow leopard (10.6) or OS X tiger (10.4) also can be used?
thnx
babak55 is offline   Reply With Quote
Old   September 21, 2010, 16:05
Bruno,
Strange, it is the original source code, shouldn't it be just fine to compile regardless of platform on which I run it?
I tried to add that option inside the source code, but the problem still persists. Please find present output in attached txt file.
Thank you,
K
PS. Answering Babak's question, OpenFOAM should run on any OS X operating system (including Tiger).
Old   September 21, 2010, 16:11
Forgive me. This time I modified each of the Make/options file from each of the solvers. This time the solvers compiled, however, what makes me uncomfortable is the bit with "unused variable" as you can see in previously attached output file, log2.txt.
Thanks for your time and help!
K
Old   September 21, 2010, 19:21
Bruno Santos
Hi Paka,
Don't worry about that, it also happens in the Linux version. Those warnings are related to some variables that are defined in a general header file that is used by several solvers. I believe that some use them, others don't. And since the solvers with the warnings work without any problems, it's probably left in the low priority queue of "FIXME" list
Best regards,
Bruno
Thread Tools
Trackbacks are On
Default patches not appearing in paraview ozzythewise OpenFOAM Native Meshers: blockMesh 6 January 31, 2011 10:41
internal faces between patches created with snappyHexMesh romant OpenFOAM Mesh Utilities 0 August 17, 2009 08:40
Courant number, patches, etc oort OpenFOAM 1 July 24, 2009 18:05
SnappyHexMesh large number of patches written prapanj OpenFOAM Mesh Utilities 0 July 15, 2009 08:11
radiation patches, viewfactors beams CD-adapco 1 March 12, 2009 08:39
