April 19, 2012, 01:03 |
paraview installation
Timo Kulju
Rep Power: 16 |
Hi all!
I'm trying to install paraview 3.12.0 to Centos-5-x86_64, but every time the build process terminates at Code:
[ 82%] Building CXX object ParaViewCore/ServerImplementation/CMakeFiles/vtkPVServerImplementation.dir/vtkPVSessionCore.cxx.o In file included from /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkPVSessionBase.cxx:22:0: /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkSMMessage.h:30:29: serious error: vtkPVMessage.pb.h: no such file or directory compilation terminated. Code:
/opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/protoc: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.10' not found (required by /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/libprotobuf.so) /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/protoc: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.10' not found (required by /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/libprotoc.so) /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/protoc: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/libprotoc.so) /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/protoc: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /opt/share/apps/OpenFOAM/ThirdParty-2.1.0/build/linux64Gcc45/paraview-3.12.0/bin/libprotoc.so) Code:
withMPI=true MPI_MAX_PROCS=32 # Python support: # note: script will try to determine the appropriate python library. # If it fails, specify the path using the PYTHON_LIBRARY variable withPYTHON=true #PYTHON_LIBRARY="/usr/lib64/libpython2.4.so.1.0" PYTHON_LIBRARY="/usr/lib64/libpython2.6.so.1.0" # MESA graphics support: withMESA=true MESA_INCLUDE="/usr/include/GL" MESA_LIBRARY="/usr/lib64/libOSMesa.so" # extra QT gui support (useful for some third party apps) withQT=true # Set the path to the Qt-4.5 (or later) qmake if the system Qt is older QMAKE_PATH="/opt/share/apps/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc45/qt-4.6.2/bin/qmake" # Set the path to cmake CMAKE_PATH="/opt/share/apps/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc45/cmake-2.8.3/bin" Timo |
April 19, 2012, 04:59 |
solution found
#2 | ||
Timo Kulju
Rep Power: 16 |
Hi!
Ok, I found the solution. Installing OpenFOAM with centFOAM, and compiling ParaView-3.10.1 instead of 3.12.0 solved the problem. In addition one has to modify the Quote:
http://www.cfd-online.com/Forums/blo...-qt-4-6-4.html Cheers, Timo |
ParaView installation problem on Suse 11.4 | victorz | OpenFOAM Installation | 4 | February 6, 2012 17:26 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
