OpenFOAM-1.6-ext installation on OpenSUSE 12.1 |
April 25, 2012, 07:12 |
Rep Power: 14 |
Hello everybody,
the last days I tried to install OpenFOAM-1.6-ext on OpenSUSE 12.1. During installation I followed the instructions of this thread http://www.cfd-online.com/Forums/ope...1-4-64bit.html (first Post) and the last post of the following thread http://www.cfd-online.com/Forums/ope...11-10-x64.html to get ParaView working. Finally, I didn't really succeed. I attached my log-files of the Third-Party-Installation and of OpenFOAM. I guess it is a problem with openmpi. I thought I installed it correctly, but as newbie I'm not really sure. I would be very thankful if someone could help me and give me a hint. Thank you in advance! Best regards, Matthias Last edited by matthiass; April 25, 2012 at 10:56. |
April 25, 2012, 07:13 |
Rep Power: 14 |
Here are the other logs!
April 25, 2012, 07:53 |
Rep Power: 14 |
I forgot the foamInstallationTest.
Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux-3eo1.site OS: Linux version 3.1.10-1.9-desktop ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/mias/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/mias/OpenFOAM/mias-1.6-ext no no $WM_THIRD_PARTY_DIR ...OpenFOAM/OpenFOAM-1.6-ext/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/mias/OpenFOAM/OpenFOAM-1.6-ext yes yes yes $FOAM_APPBIN ...ext/applications/bin/linux64GccDPOpt yes yes yes $FOAM_SITE_APPBIN ...OAM/site/1.6-ext/bin/linux64GccDPOpt no no $FOAM_USER_APPBIN ...ext/applications/bin/linux64GccDPOpt no no $WM_DIR ...mias/OpenFOAM/OpenFOAM-1.6-ext/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OpenFOAM-1.6-ext/lib/linux64GccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...OAM/site/1.6-ext/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN ...OAM/mias-1.6-ext/lib/linux64GccDPOpt no no $MPI_ARCH_PATH ...nmpi-1.4.3/platforms/linux64GccDPOpt yes no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.6.2 Minimum required: 4.3.1 gcc 4.6.2 WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.4 /usr/bin/gzip tar 1.26 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/mias/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
April 25, 2012, 10:20 |
Disabled
Rep Power: 16 |
hi mathias i am doing the same it is the first time for me to compile openfoam1.6-ext on opensuse 12.1 and there are also some problems in the thirdparty
./Allmake.stage3 give the problem about mesquite-2.1.2 so i think it is a problem with the distribution and openfoam that need to be find out i dont know what really happens till now |
April 25, 2012, 10:33 |
Disabled
Rep Power: 16 |
why you installing mesquite2.99?
April 25, 2012, 10:41 |
#6 | |
Rep Power: 14 |
Hi Tajoooko,
I replaced mesquite-2.1.2 by mesquite-2.99 as proposed in this thread http://www.extend-project.de/user-fo...ation-openfoam by Maria Garcia-Camprubi. Quote:
Best regards, Matthias |
April 25, 2012, 11:13 |
Disabled
Rep Power: 16 |
ah yes i do it now too it works fine but the next error is about
mpi.h --> not found |
April 25, 2012, 11:19 |
Rep Power: 14 |
Do you mean in one of the wmake-log-files?
#9 |
Disabled
Rep Power: 16 |
common.h:84:28: fatal error: mpi.h: No such file or directory
it seems that he is not finding the openMPI instalation but thirdparty Allmake.stage3 gives: ======================================== Starting ThirdParty AllMake: Stage2 ======================================== Package name : openmpi-1.4.3 Package URL : http://www.open-mpi.org/software/omp...i-1.4.3.tar.gz RPM spec file name: openmpi-1.4.3.spec Additional flags : Updating the ThirdParty environment variables before building package openmpi-1.4.3 Package openmpi-1.4.3 is already installed Done installing package ======================================== Done ThirdParty AllMake: Stage2 ======================================== |
May 2, 2012, 15:47 |
#10 |
Rep Power: 14 |
I finally succeeded the installation of OF-1.6-ext on OpenSUSE 12.1!
In my case the ThirdParty openmpi-1.4.3 doesn't install properly (until now I don't know why), because of that I used the systems openmpi-1.4.3 (I adjusted this in prefs.sh). After that I got the next error: Code:
+ wmake libso mesquiteMotionSolver /usr/lib64/gcc/x86_64-suse-linux/4.6/../../../../x86_64-suse-linux/bin/ld: cannot find -lmesquite collect2: ld returned 1 exit status make: *** [/home/matthias/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmesquiteMotionSolver.so] Fehler 1 The next error was: Code:
In file included from vtkPV3Foam.C:28:0: ../PV3FoamReader/vtkPV3FoamReader.h:31:43: fatal error: vtkMultiBlockDataSetAlgorithm.h: Datei oder Verzeichnis nicht gefunden compilation terminated. make[3]: *** [Make/linux64GccDPOpt/vtkPV3Foam.o] Fehler 1 Code:
cd ~/OpenFOAM/OpenFOAM-1.6-ext/applications/utilities/postProcessing/graphics/PV3FoamReader/vtkPV3Foam/Make Code:
-I$(PARAVIEW_INCLUDE_DIR)/paraview-3.12 \ to -I$(PARAVIEW_INCLUDE_DIR)/paraview-3.10 \ Maybe this will help someone! Best regards, Matthias |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results | Arnoldinho | OpenFOAM Community Contributions | 7 | December 9, 2010 16:29 |
Installation of OpenFOAM 1.5-dev and its fitness for FSI? | Martin_ | OpenFOAM Installation | 24 | November 16, 2010 17:39 |
OpenFOAM 1.7.0 on OpenSUSE 11.1 | Bufacchi | OpenFOAM Installation | 8 | August 6, 2010 09:57 |
kOmegaSST in openfoam 1.6 | Gearb0x | OpenFOAM | 2 | March 3, 2010 06:02 |
