please help me!
Like Tree1Likes
Old   April 27, 2012, 04:27
Question please help me!
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi,
anybody is here that explain me how can I install OpenFOAM on Linux Ubuntu? does it have a graphical environment or it just has coding environment?
I'm a beginner in openfoam and linux!
I have downloaded it with thirdparty-2.1.0 before.
thank a lot
adambarfi is offline   Reply With Quote
Old   April 27, 2012, 05:41
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by adambarfi View Post
hi,
thank a lot
Please consider this link http://openfoamwiki.net/index.php/Ho..._Message_Board, read it and then post your questions accordingly. How OpenFOAM is installed on Ubuntu Linux is explained on the website http://www.openfoam.org/download/ubuntu.php, there you will also everything else you need to know about openfoam and how it works for starters. Additionally, read the last part of bruno's blog post http://www.cfd-online.com/Forums/blo...rty-tools.html and get familiar with the system.
~roman
romant is offline   Reply With Quote
Old   April 27, 2012, 06:07
adambarfi's Avatar
Mostafa Mahmoudi
thank you so much, I'll be back if I have questions.
Old   April 28, 2012, 06:57
adambarfi's Avatar
Mostafa Mahmoudi
hi,
When I want to install OpenFOAM-1.7.1 on OpenSUSE it says:
System management is locked by the application with pid 4511 (/usr/sbin/packagekitd).
Close this application before trying again.
What do I do, please?
Old   April 28, 2012, 16:40
Retired Super Moderator
Bruno Santos
Greetings to all!
@Mostafa: did you search for this online? The first post I got was this: http://superuser.com/questions/83997...by-packagekitd
Basically all you needed to do was:
kill 4511
#or if you aren't in root mode
sudo kill 4511
Best regards,
Bruno
Old   April 28, 2012, 23:28
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by wyldckat View Post
Greetings to all!
kill 4511
sudo kill 4511
Best regards,
Bruno
thank you Bruno
I'm a new user in linux!
Old   May 10, 2012, 12:35
adambarfi's Avatar
Mostafa Mahmoudi
when I want to install OpenFOAM-2.1.0 on Ubuntu it says:
mostafa@mostafa-desktop:~$ sudo apt-get install build-essential flex bison cmake zlib1g-dev qt4-dev-tools libqt4-dev gnuplot libreadline-dev libxt-dev
[sudo] password for mostafa:
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
flex is already the newest version.
bison is already the newest version.
Package cmake is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package cmake has no installation candidate
Is it OK!!!!!!!!!
Old   May 10, 2012, 14:54
Bruno Santos
Hi Mostafa,
That's strange... what Ubuntu version do you have installed? Did you do any upgrade? Does your machine have internet connection?
Best regards,
Bruno
Old   May 11, 2012, 00:45
adambarfi's Avatar
Mostafa Mahmoudi
Hi Wyldckat,
thank you for your reply.
CAELinux 2011
This release is built on an updated Ubuntu 10.04.3 LTS 64 bit base with a focus on the upgrade of the CAE softwares and the addition of tutorials & wizards to make your first steps easier.
I think I should use the previous version of OpenFOAM, such as 1.7.0.
Old   May 11, 2012, 02:35
romant's Avatar
Roman Thiele
Hi Wyldckat,
CAELinux 2011
Looking at the CAElinux website, CAElinux 2011, comes with OpenFOAM 2.0.1, therefore you should even be able to install 2.0.1 without hassle from the sources if I understand this right.
On the live DVD that you get from CAElinux, Ubuntu 2.0.1 is already installed and when installing the liveDVD onto your hard disk you should have OpenFOAM available.
~roman
Old   May 11, 2012, 02:44
adambarfi's Avatar
Mostafa Mahmoudi
thank you Roman,
It just has OpenFOAM Terminal !!!! what should I do?
Old   May 11, 2012, 02:47
romant's Avatar
Roman Thiele
OpenFOAM only runs in terminal, for graphical post processing you will have to use paraview, which is called from the terminal in your case directory by running paraFoam. I suggest you go to http://www.openfoam.org/docs/user/ and read the introduction as well as work through the first tutorials. This way you will get used to OpenFOAM, how it works and also learn a little bit about how to use linux.
adambarfi likes this.
~roman
Old   May 11, 2012, 03:00
adambarfi's Avatar
Mostafa Mahmoudi
Dear Roman, thank you so much!!!
I'm a new user of Linux
I doubt that OpenFOAM, itself is really a terminal or not,
again thank you.
Old   May 11, 2012, 06:19
Bruno Santos
Read this thread: http://www.cfd-online.com/Forums/ope...cae-linux.html
Old   August 25, 2012, 14:31
Manfredi
Meltedbrain is on a distinguished road
Hello everyone,
i'm new in Linux and i'm trying to install OpenFOAM on Ubuntu. I'm following the instructions at this link http://www.openfoam.org/download/source.php , but i can't understand what i have to do at this point:
"Go to the top-level source directory $WM_PROJECT_DIR and execute the top-level build script ./Allwmake." in paragraph Building the Sources.
What am i supposed to do?
Please try to be the more "explainful" as you can!
Thank you
Meltedbrain is offline   Reply With Quote
Old   August 25, 2012, 14:58
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by Meltedbrain View Post
Hello everyone,
Thank you
Dear Manfredi,
just go to $WM_PROJECT_DIR and run ./Allwmake as below:
cd $WM_PROJECT_DIR
./Allwmake
it will make all the make folders in OF.
Old   August 25, 2012, 15:01
adambarfi's Avatar
Mostafa Mahmoudi
dear Bruno,
Thank you so much
Mostafa Mahmoudi
Old   August 25, 2012, 17:30
Manfredi
Here is what i tried to do.... but looks like it did't work:
manfredi@manfredi-MacBookAir:~$ cd $WM_PROJECT_DIR
manfredi@manfredi-MacBookAir:~$ ./Allwmake
bash: ./Allwmake: File o directory non esistente
manfredi@manfredi-MacBookAir:~$ cd -
/home/manfredi
manfredi@manfredi-MacBookAir:~$ '/home/manfredi/OpenFOAM/OpenFOAM-2.1.1/Allwmake'
/home/manfredi/OpenFOAM/OpenFOAM-2.1.1/Allwmake: 4: /home/manfredi/OpenFOAM/OpenFOAM-2.1.1/Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
    The environment variables are inconsistent with the installation.
    Check the OpenFOAM entries in your dot-files and source them.
Maybe i missed something in the previews steps?
Is it correct to add line
                 source $HOME/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
in $HOME/.bashrc file before it says
end-of-file
Thank you
P.s. "non esistente" means "do not exist"
Old   August 26, 2012, 00:16
adambarfi's Avatar
Mostafa Mahmoudi
/home/manfredi
end-of-file
Thank you
Dear Manfredi,
I had such problem before, the problem is about environment variables, they aren't fixed correctly.
run 'echo $SHELL' to see whether the bash or ksh is running or tcsh or csh. then you should add the below code before end-of-file of bashrc or cshrc file, for example, in '$HOME/OpenFOAM/OpenFOAM-x.x.x/etc' directory.
source $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc
then according to http://www.openfoam.org/archive/2.1....oad/source.php resume the installing.
for more details see this link by Bruno:
Advanced tips for working with the OpenFOAM shell environment
Old   August 26, 2012, 07:10
Bruno Santos
Greetings to all!
@Meltedbrain:
/home/manfredi
If you want to build directly on Mac OS, follow these instructions: http://openfoamwiki.net/index.php/Ho...enFOAM_v21_Mac
Best regards,
Bruno
