Home > Forums > OpenFOAM Installation
How can I publish my build of OF-2.1.0 ?
Old   May 8, 2012, 01:13
Default How can I publish my build of OF-2.1.0 ?
John Smith
psfan is on a distinguished road
System: Centos 6.0, icc, ifort, intelmpi
The system administrator allows me to publish my binary build of OF-2.1.0 in directory /export/OpenFOAM. I compiled the source as a normal user "john", not a root. The problem is only user john, i.e. myself, can run the binary code, others will get "Segmentation fault" and exit code of "139". I have checked the shell enviroment variants, library path, MPI path, ..., ensure the other user's are the same as mine. The problem still exist. Who can help me ?
psfan is offline   Reply With Quote
Old   May 8, 2012, 02:29
Alberto Passalacqua
They could compile the same code you have, in case you can share it.
An easy alternative could be to build a statically linked executable with:
wmake exe
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   May 8, 2012, 20:50
John Smith
wmake exe
Best,
Thank you for your replying. Since many users on the cluster will use OpenFOAM, it's better to publish a binary code so that they needn't spend too much time to compile the source code individually. To build a statically linked executable is a good idea, I'll have a try. Thanks again.
Old   May 9, 2012, 02:59
Mark Olesen
olesen will become famous soon enough
Perhaps incorrect permissions on some files? You should ensure that everyone has read permission and can execute all directories and files that are meant to be executed:
chmod -R a+rX dir-name
Also make sure that there are no special libraries lurking in your $FOAM_USER_LIBBIN that are used by you, but not seen by the others.
olesen is offline   Reply With Quote
Thread Tools
Trackbacks are On
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
mpich2 build for hpf taw Main CFD Forum 0 April 6, 2008 03:34
OpenFOAM build from source instructions tj22 OpenFOAM Installation 7 April 6, 2006 16:15
CFX Build 5 question... cfd guy CFX 6 June 19, 2001 22:38
