Installing OpenFOAM-2.1.x on SuSE Linux 10.1 cluster
Hello everybody,
Has anyone out there tried to install OF-2.1.x on a SuSE linux 10.1 machine. I can see that the system requirements say OpenSuSe 11.3 and 11.4. But there is a work around, it would be great for the only cluster at my disposal is this one. Thank you for your help and best regards. |
Greetings ebah6,
I haven't tested in openSUSE 10.1, but here is an old blog post of mine that explains how one can install a recent OpenFOAM on an old Linux: Building OpenFOAM 2.0.1 on old Linux OSes - test case Ubuntu 8.04 Best regards, Bruno |
Thank you Bruno,
I am trying the installation but couldn't find the binutils for OF2.1.x. For example, wget "https://raw.github.com/wyldckat/ThirdParty-2.0.x/binutils/makeBinutils" is available but not for ../ThirdParty-2.1.x/.. I wonder whether there is an alternative. For now I am going ahead and use the 2.0.1 files to see whether they work. Please let me know your thoughts. Thank you. |
Hi ebah6,
Use the ones already listed at Quote:
Hello Bruno and everybody else,
I think my SuSE version is too old (version 10.1) to support OpenFOAM-2.1.0/x So I tried to install the missing libraries that are required by OF but it led me to infinite chain library dependencies ( i.e., any library that I want to install need another library that doesn't exist and so on ...) My current problem is as follows, I need to use a SuSE-10.1 cluster but couldn't install OF on it due to what I mentioned above. So would it some how possible to generate kind of executables from my desktop machine and run them in the cluster without installing OF on it? I know this may sound stupid but what stupid is when we are 'desperate'? I hope that someone can help with this issue or with a work around. Best regards all. |
Hi ebah6,
Well, you can start reading here: http://www.cfd-online.com/Forums/ope...tml#post324236 post #3 There you'll find two possibilities:
Bruno |
Thank you Bruno, I appreciate.
