Installing OpenFOAM-2.1.x on SuSE Linux 10.1 cluster
Old   May 10, 2012, 18:12
Default Installing OpenFOAM-2.1.x on SuSE Linux 10.1 cluster
Elh. A2. BAH
ebah6 is on a distinguished road
Hello everybody,
Has anyone out there tried to install OF-2.1.x on a SuSE linux 10.1 machine.
I can see that the system requirements say OpenSuSe 11.3 and 11.4.
But there is a work around, it would be great for the only cluster at my disposal is this one.
Thank you for your help and best regards.
ebah6 is offline   Reply With Quote
Old   May 11, 2012, 06:17
Retired Super Moderator
Bruno Santos
Greetings ebah6,
I haven't tested in openSUSE 10.1, but here is an old blog post of mine that explains how one can install a recent OpenFOAM on an old Linux:
Building OpenFOAM 2.0.1 on old Linux OSes - test case Ubuntu 8.04
Best regards,
Bruno
Old   May 11, 2012, 10:46
Elh. A2. BAH
Thank you Bruno,
I am trying the installation but couldn't find the binutils for OF2.1.x.
For example,
wget "https://raw.github.com/wyldckat/ThirdParty-2.0.x/binutils/makeBinutils" is available but not for ../ThirdParty-2.1.x/..
I wonder whether there is an alternative.
For now I am going ahead and use the 2.0.1 files to see whether they work.
Please let me know your thoughts.
Thank you.
Old   May 11, 2012, 11:55
Bruno Santos
Hi ebah6,
Use the ones already listed at
Now let us go to the ThirdParty folder and get a couple of important scripts:
that they should work for 2.1.x as well.
Best regards,
Bruno
Old   May 18, 2012, 12:09
Elh. A2. BAH
Hello Bruno and everybody else,
I think my SuSE version is too old (version 10.1) to support OpenFOAM-2.1.0/x
So I tried to install the missing libraries that are required by OF but it led me to infinite chain library dependencies ( i.e., any library that I want to install need another library that doesn't exist and so on ...)
My current problem is as follows, I need to use a SuSE-10.1 cluster but couldn't install OF on it due to what I mentioned above.
So would it some how possible to generate kind of executables from my desktop machine and run them in the cluster without installing OF on it?
I know this may sound stupid but what stupid is when we are 'desperate'?
I hope that someone can help with this issue or with a work around.
Best regards all.
Old   May 18, 2012, 13:12
Bruno Santos
Hi ebah6,
Well, you can start reading here: http://www.cfd-online.com/Forums/ope...tml#post324236 post #3
There you'll find two possibilities:
  • static building;
  • or manual/selective packaging.
Best regards,
Bruno
Old   May 18, 2012, 15:28
Elh. A2. BAH
Thank you Bruno, I appreciate.
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
OpenFoam Installation in Redhat Enterprise linux 5 sahm OpenFOAM Installation 78 November 1, 2011 15:22
Installing OpenFOAM 1.7.x on CAElinux without Internet Connection joel.lehikoinen OpenFOAM Installation 3 June 14, 2011 11:09
Installing OpenFOAM in Ubuntu LINUX 510 Breeze derjames OpenFOAM Installation 0 April 7, 2006 08:22
OpenFOAM in a Linux Cluster gedanken OpenFOAM Installation 1 August 25, 2005 13:32
