Issues related to the OpenFOAM CAE-Linux based live distribution |
May 24, 2012, 08:14 |
Tomislav Maric
Rep Power: 21 |
Hi everyone,
feel free to compliment/complain on the live USB distribution provided for the 7Th OpenFOAM Workshop in this thread. For more information regarding the disk, see the post in the Announcement section: http://www.cfd-online.com/Forums/ope...tml#post362847 |
May 26, 2012, 09:51 |
Hello Tomislav,
the burned DVD-Iso works well, but creating a USB-memory Stick via "usb-creator-kde" leads to a non bootable media I tried 16GB PNY "Micro Sleek Attaché" and a 32GB CnMemory "Spaceloop" Stick I tried to boot on two Laptops a Dell XPS and a very old Medion Laptop both showed up vesamenu.c32 not a COM32R image the workaround is type live "carriage return" "carriage return" https://bugs.launchpad.net/ubuntu/+s...ux/+bug/617779 http://wiki.ubuntuusers.de/Live-USB#Bootprobleme |
May 26, 2012, 09:54 |
#3 | |
Tomislav Maric
Rep Power: 21 |
Thanks a lot for the info! Well, I can just tell you that the "usb-creator-gtk" seems to work, I didn't try to burn it using "usb-creator-kde". Can you try it using the "-gtk" version of the software? Also, have you checked the md5sum? On thursday I've burned around 10 USB sticks, so far we have tested it on around 7 different laptops and it booted normally. |
May 26, 2012, 10:09 |
#5 | |
Tomislav Maric
Rep Power: 21 |
I think I've written in the Announcement post that you should hit the "return" key when you see the "boot: " black screen... Both Joel and me could not get rid of that bug. |
May 26, 2012, 16:52 |
Bernhard
Rep Power: 21 |
I used the -gtk on Ubuntu 11.10 and got the same error message as Elvis. However, also the same solution.
May 26, 2012, 17:55 |
Hi Tomislav,
i made a permanent install on my harddisk (just for the speed). Now I struggle with the wlan-adapter. I installed linux-firmware, and sudo modprobe iwlagn lsmod | grep iwl iwlagn 123060 0 iwlcore 125250 1 iwlagn mac80211 238928 2 iwlagn,iwlcore led_class 3764 1 iwlcore cfg80211 148725 3 iwlagn,iwlcore,mac80211 but I do not know how to configure wlan ifconfig eth0 Link encap:Ethernet HWaddr 14:fe:b5:a0:8e:c0 ... lo Link encap:Local Loopback ... but no wlan0 ipmaddr 1: lo 2: eth0 3: pan0 "Network Tools" does not show more devices (lo, eth0, pan0) Network Conections has a section "Wireless" and seems to be the place to configure my wlan but I do not get WLAN to work. Can somebody help on this topic? |
May 26, 2012, 19:23 |
=>/etc/network/interfaces
This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback allow-hotplug wlan0 iface wlan0 inet dhcp wpa-psk mysecretpassword wpa-ssid mywlan |
May 26, 2012, 19:24 |
May 27, 2012, 16:56 |
Tomislav Maric
Rep Power: 21 |
@Elvis
Hm... I am not sure where the problem lies. Basically, the core of the distribution is ubuntu LTS 10.04 64 Bit, with all the firmwares installed that I could find. What is the type of your wlan card? |
May 27, 2012, 17:29 |
#11 |
Hi Tomislav,
my Laptop is Dell-System-XPS-L702X the wlan works with Kubuntu using a 2.6.38-8-generic Kernel lspci | grep Net 03:00.0 Network controller: Intel Corporation Centrino Wireless-N 1030 (rev 34) lsmod | grep iwl iwlagn 333500 0 iwlcore 167503 1 iwlagn mac80211 294370 2 iwlagn,iwlcore cfg80211 178528 3 iwlagn,iwlcore,mac80211 iwconfig lo no wireless extensions. eth0 no wireless extensions. wlan0 IEEE 802.11bgn ESSID: ipmaddr 1: lo 2: eth0 3: wlan0 But CAElinux 2.6.32-41-generic gets different results lspci | grep Net 03:00.0 Network controller: Intel Corporation Device 008a (rev 34) lsmod | grep iwl iwlagn 123060 0 iwlcore 125250 1 iwlagn mac80211 238928 2 iwlagn,iwlcore led_class 3764 1 iwlcore cfg80211 148725 3 iwlagn,iwlcore,mac80211 iwconfig lo no wireless extensions. eth0 no wireless extensions. pan0 no wireless extensions. |
May 27, 2012, 17:34 |
#12 | |
Tomislav Maric
Rep Power: 21 |
Your wifi firmware is standard.... need more info: 1) When did you download the ISO? 2) Did you try to connect to the wired connection? 2.1) Did your nm-applet start: do you see the network manager applet running on the top panel in Gnome? Like, if you connect to the wired network, you should see an icon appearing in the Notification Area on the panel, and a notification window telling you that you are connected. There was a bug with the nm-applet that I needed to fix. I've uploaded the new iso version on last Friday, around 16:30, if you have downloaded the .iso file before that, you have maybe missed the update... |
May 30, 2012, 07:04 |
problem with Mac
#15 |
Hi Tomislav,
I am now using Mac Pro with Mac OSX Lion. I tried to create a bootable USB from .ISO file by following the instruction here https://help.ubuntu.com/community/In...k#From_Mac_OSX. But it seems that I can not boot from the USB. Using DiskUtility, it says that the USB has Unformatted Partition Map Scheme while looking at http://support.apple.com/kb/HT1948 they say that a bootable USB stick should have GUID partition type. I tried to partition my USB using GUID type first and then burn .ISO file to that USB. But it doesn't work. I'm wondering if other Mac users also have similar problem. Looking to hear advices from you to fix that. Duong |
May 30, 2012, 07:15 |
#16 | |
Tomislav Maric
Rep Power: 21 |
I'm sorry, but I never used Macs.... I have also heard that last year people had problems with the USB disk on macs. I don't have access to a Mac, so I don't know if its possible for me to fix this... |
May 30, 2012, 07:49 |
#17 |
Pablo Higuera
Rep Power: 19 |
Hi Duong,
it is not possible for most of the newest Macs to boot from USB other systems than OS X. I've tried a long time with linux, even booting from CD and telling to start the USB instead of the CD itself, and no good results so far. The easiest solution is to get a virtual machine... |
May 30, 2012, 08:25 |
#18 |
Hi Pablo,
Indeed, using virtual machine solve the problem. I'm now trying to boot with USB. Will let you know if I get good results. Duong |
May 30, 2012, 08:49 |
#19 | |
Tomislav Maric
Rep Power: 21 |
June 7, 2012, 14:38 |
#20 |
Pablo Higuera
Rep Power: 19 |
I've just burnt mine using Ubuntu 10.04 with usb-creator-gtk .
At first it was non-persistent, but changing grub.cfg , adding "persistent" option after "quiet splash -- " did the trick. Everything works now. Reference: http://ubuntuforums.org/showthread.php?t=1749442 |
OpenFOAM-dev Live USB DVD, based on kubuntu | henrik | OpenFOAM Installation | 30 | January 24, 2020 12:25 |
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio | alberto | OpenFOAM | 40 | May 23, 2010 17:15 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 16:39 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
