-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   problem on installing swak4Foam (http://www.cfd-online.com/Forums/openfoam-installation/102609-problem-installing-swak4foam.html)
navid2 May 29, 2012 19:42
hello
when i try to install the swak4Foam by the command "./Allwmake" i receive the following errors and the process get in an infinite loop.
navid@navid-laptop:~/Desktop/swak4Foam/swak4Foam$ ./Allwmake
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Bison is version 2.4.1
OpenFOAM-version: Major 2 Minor 1 Patch 0
No swak4FoamParsers/foamVersion4swak.H. Generated
make: Warning: File `/opt/openfoam210/wmake/rules/linux64Gcc/c++Opt' has modification time 1.7e+07 s in the future
make: warning:  Clock skew detected.  Your build may be incomplete.
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file printSwakVersion.C
Making dependency list for source file SurfacesRepository.C
Making dependency list for source file SetsRepository.C
Making dependency list for source file GlobalVariablesRepository.C
Making dependency list for source file ExpressionDriverWriter.C
Making dependency list for source file ExpressionResult.C
Making dependency list for source file StoredExpressionResult.C
Making dependency list for source file swakRegistryProxySurface.C
Making dependency list for source file swakRegistryProxySet.C
Making dependency list for source file FieldValueExpressionParser.yy
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionParser.yy
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionParser.yy
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionParser.yy
could not open file CalculatedPointPatchField.H for source file FieldValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file SubsetValueExpressionParser.yy
could not open file SubsetValueExpressionParser.tab.hh for source file SubsetValueExpressionParser.yy
Making dependency list for source file CommonValueExpressionDriver.C
Making dependency list for source file FieldValueExpressionLexer.ll
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionLexer.ll
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionLexer.ll
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionLexer.ll
could not open file CalculatedPointPatchField.H for source file FieldValueExpressionLexer.ll
Making dependency list for source file FieldValueExpressionDriver.C
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionDriver.C
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionDriver.C
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionDriver.C
could not open file CalculatedPointPatchField.H for source file FieldValueExpressionDriver.C
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
i would be happy if somebody can help me solving this problem.
thanks
gschaider May 29, 2012 21:41
Originally Posted by navid2 (Post 363692)
hello
thanks
I appreciate you not posting the whole log-file, but up until now everything is looking fine (except for the clock skew, but that is strictly a problem of your system - impressive clock skew by the way. 1.7e+07s. Respect). The "could not open file" messages are about files that are going to be generated by flex and bison.
The ultimate test is letting ./Allwmake run. The rerun it. If there are no more messages: everything is alright
gschaider May 30, 2012 04:32
hello
I overread the "infinite loop" when answering. Really? How does that happen? (there is no looping construct in the Allwmake files.)
