broken foamInstallationTest?!
I have recently compiled OpenFoam 2.1.x on both a Suse and a Ubuntu linux machine (64-bits) and in both cases the compilation went without problems and I could run the icoFoam test case (and, by now, I have successfully ran other cases as well). Funny thing is: foamInstallationTest tells me that the OpenFOAM environment is not configured. Is this a bug? Or is it possible that the absence of the standard thirdparty programs is causing this? Not really an issue, but I was just curious if anyone knows! |
Greetings Michiel,
Well, you could be more specific ;) Such as:
Best regards, Bruno |
1/2) Nothing, I don't have a thirdparty-2.1.x folder 3) Code:
Executing /home/michiel/OpenFOAM/OpenFOAM-2.1.x/bin/foamInstallationTest: |
LOL! Indeed, simply by renaming the folder "ThirdParty-2.1.x", the script indicates that things aren't OK. After I simply create an empty folder named "ThirdParty-2.1.x", the script no longer reports the error :D
And interesting, the script doesn't properly check if the MPI built with is available for execution, so even if icoFoam exists but doesn't work, it doesn't give out a critical message... OK, here's what I know and my deduction of their point of view:
Reporting this as a bug is a start, but they probably won't fix it and might close the report with "won't fix" or something like that. Therefore, such a report should be done with a proposition for a proper fix, which takes into account:
