Paraview installation on scientific linux?? |
July 17, 2012, 06:03 |
EllieM
I'm not a newbie, but still not too technical! I have never had a problem installing in fedora, but when my laptop died I decided that I could stomach gnome3 nor more, hence SL. I have a fresh installation of SL6.2, 64 bit fully updated. Openfoam appears to have installed without a hitch, I pulled the latest release from the git repository yesterday. When I get to the ./makeParaview command, I get *** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH Can't pretend to know what this means! So I tried running ./makeQt and got --------------- Starting build: Qt-4.7.3 ./makeQt: line 107: cd: /home/ellie/OpenFOAM/ThirdParty-2.1.x/qt-everywhere-opensource-src-4.7.3: No such file or directory I apologise if this is a duplicate post, I spent all afternoon yesterday (& this morning) trawling forums, google searches not much use, especially when I am not entirely sure what I am looking for! Thanks in advance |
July 17, 2012, 06:29 |
Niels Nielsen
Rep Power: 27 |
Hi you need to install qt4
yum install qt4-devel
Linnemann PS. I do not do personal support, so please post in the forums. |
July 17, 2012, 06:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings EllieM and welcome to the forum!
This is a bit outdated, but the principle is the same: Building ParaView 3.10.1 with custom Qt 4.6.4 Adapt 4.6.4 to 4.7.3 and 3.10.1 to 3.12.0 and you should be good to go. Additionally, you might already have a valid Qt installation. Try: Code:
qmake-qt4 --version edit: Linnemann, you got 3 minutes ahead of me Best regards, Bruno
July 17, 2012, 06:41 |
EllieM
Hi, thank you both for getting back to me..
linnemann, when I run 'sudo yum install qt4-devel' I get Package 1:qt-devel-4.6.2-24.el6.x86_64 already installed and latest version Nothing to do wyldeckat, 'qmake-qt4 --version' gives QMake version 2.01a Using Qt version 4.6.2 in /usr/lib64 I am a bit lost in the link for the post you sent, sorry - where should I be looking? Thanks again |
July 17, 2012, 06:57 |
Niels Nielsen
Rep Power: 27 |
In the makeParaview script you need to change the following lines
# Set the path to the Qt-4.5 (or later) qmake if the system Qt is older QMAKE_PATH="" # Set the path to cmake CMAKE_PATH="" Code:
which qmake-qt4 Code:
which cmake yum install cmake I think this should work
Bruno Santos
Rep Power: 128 |
Instead of simply running makeParaView, run it like this:
./makeParaView -qmake `which qmake-qt4` > makePV.log 2>&1 The rest is the same as explained in the official OpenFOAM instructions.
July 17, 2012, 07:37 |
EllieM
Thank you again for both getting back to me.
I followed both your sets of instructions makeParaview has been changed to # Set the path to the Qt-4.5 (or later) qmake if the system Qt is older QMAKE_PATH="/usr/bin/qmake-qt4" # Set the path to cmake CMAKE_PATH="/usr/bin/cmake" When I run ./makeParaView -qmake `which qmake-qt4` > makePV.log 2>&1 my makePV.log tells me that CMake Error at VTK/Utilities/vtkhdf5/CMakeLists.txt:1 (cmake_minimum_required): CMake 2.8 or higher is required. You are running version 2.6.4 There are also a couple of other errors, but they appear to be connected. I have the most up to date version available on SL, so I enabled the atrpms repo (as suggested here http://www.linuxforums.org/forum/red...linux-6-a.html) and I still cannot get cmake 2.8.... I am now going to walk away from the machine before it ends up in a million pieces! |
July 17, 2012, 07:49 |
Niels Nielsen
Rep Power: 27 |
Download the latest release of cmake
yum install ncurces-devel unpack cmake go to cmake dir ./configure --prefix=/usr/local make && make install run which cmake should be in /usr/local/bin and not /usr/bin
July 17, 2012, 07:57 |
Bruno Santos
Rep Power: 128 |
Or as an alternative to Linnemann's instructions - from within the ThirdParty folder run these commands:
wget "http://www.openfoam.org/mantisbt/file_download.php?file_id=143&type=bug" -O getCmake wget "https://raw.github.com/OpenFOAM/ThirdParty-2.0.x/master/makeCmake" chmod +x get* make* ./getCmake ./makeCmake > mkcmake.log 2>&1 wmSET
July 17, 2012, 08:15 |
EllieM
Thank you both for your help, but I give up!
wyldckat, your method gives me an error with Linking CXX static library libCMakeLib.a linnemann, your method gives me an error of The bug is not reproducible, so it is likely a hardware or OS problem. gmake: *** [cmBootstrapCommands.o] Error 1 --------------------------------------------- Error when bootstrapping CMake: Problem while running gmake Again, thank you both so much, I really do appreciate it, but I simply do not have the time at the moment to fix this! :-( |
May 12, 2013, 21:32 |
#11 |
Kiddosuper
encountered same problem as #7 , cmake version is not matching requried version 2.8
follow the instruction from linnemann So I download cmake 2.8 , and compile with # ./configure --prefix=/usr/local # ./bootstrap; make; make install after that, still need to modify the link for cmake # cd /usr/bin # mv cmake xxxcmake # ln -s /usr/local/bin/cmake ./ and then , problem solved |
installation, openfoam, paraview 3.12, scientific linux |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
