-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Setting environment variables: bash issue (http://www.cfd-online.com/Forums/openfoam-installation/105401-setting-environment-variables-bash-issue.html)
travonz July 30, 2012 04:29
I would like to automate environment initialization prior to OpenFOAM use.
I wrote the following bash script, but it doesn't work at all. Environment is only set inside script, when it exit the script and goes back to console, nothing changes, no variable has been defined.
#!/bin/bash
source /opt/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
source $HOME/.bashrc
cd $FOAM_RUN
Do you know how can I keep environment after script execution ?
Thanks for your help.
Xavier
wyldckat July 30, 2012 17:12
Greetings Xavier and welcome to the forum!
You should resort to an alias instead, placed in your "~/.bashrc". Example for your case:
alias of211combo='source /opt/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc; cd $FOAM_RUN'
For more on this kind of details: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
travonz July 31, 2012 03:17
Great !
Thank you very much for your advice and for the link.
sincerely,
Xavier
