-   OpenFOAM Installation (
-   -   OpenFOAM-2.1.x on OpenSUSE 12.2 failed installation (
phsieh2005 September 8, 2012 06:54
Dear OpenFOAMers,
paraview failed compilation on OpenSUSE 12.2. I am wondering if anyone here has a solution for this. Thanks!
[ 83%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o
In file included from /home/hsieh/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/Qt/Core/pqAnimationScene.cxx:57:0:
/home/hsieh/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h:75:30: error: calls to overloaded operators cannot appear in a constant-expression
make[2]: *** [Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o] Error 1
make[1]: *** [Qt/Core/CMakeFiles/pqCore.dir/all] Error 2
make: *** [all] Error 2
Installation complete for paraview-3.12.0
Set environment variables:
export ParaView_DIR=/home/hsieh/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc46/paraview-3.12.0
export PATH=$ParaView_DIR/bin:$PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12
wyldckat September 8, 2012 14:08
Greetings Pei-Ying,
openSUSE 12.2 is using Gcc 4.7, for which ParaView requires a minor tweaking in the source code. You can find a quick fix near the end of this page: - namely in step #6 "Now, in order to build ParaView 3.12.0 that comes with OpenFOAM".
Disclaimer: I haven't confirmed this myself yet, but the error message and characteristics in openSUSE 12.2 seem to fit the same profile as Fedora 17!
Best regards,
phsieh2005 September 8, 2012 18:24
Thanks a lot Bruno!
I had to use:
cd $WM_THIRD_PARTY_DIR sed -i -e 's/ClearAndSelect = Clear | Select/ClearAndSelect = static_cast<int>(Clear) | static_cast<int>(Select)/' \ ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h
./makeParaView -qmake $(which qmake-qt4) did not work
alberto September 9, 2012 02:04
Yes, that patch is correct. I used it too :-)
P.S. GeekoCFD based on openSUSE 12.2 is already available :-)
wyldckat September 9, 2012 03:56
Greetings to all!
That's because it's specific for Fedora ;) For some reason, they decided/concluded that there might be more than one version of qmake, such as qmake-qt3 or a custom build of Qt...
Best regards,
wyldckat September 27, 2012 07:42
I forgot to mention that I have already written instructions for installing OpenFOAM 2.1.1 + ParaView 3.12 on openSUSE 12.2 here:
I did the test on a virtual machine, so there might be missing some instructions related to graphics cards :(
Best regards,
