Compilation error with OF 2.1.x
1 Attachment(s)
I tried to update my OpenFOAM 2.1.x so I typed Code:
git pull Code:
./Allwmake Unfortunately, the compilation produces some error messages and stops. Some errors are about files which aren't found: DataEntryFwd.H MapDimensionedFields.H ParticleTrap.H and some errors are about "undefined reference" Foam::polyMesh::clearAdditionalGeom() Foam::pointMesh::typeName Foam::polyMesh::movePoints() After the unsuccessful compilation some commands, presumably those affected by the compilation errors, are not found anymore. |
Greetings Gerhard,
It's somewhat simple: new files were added to the main OpenFOAM library. The simplest fix is this: Code:
src Best regards, Bruno |
Thanks for the reply.
In the mean time I found a bug report about my problem and there the same solution is explained. I should have been googling a little longer before posting my problem here. http://www.openfoam.org/mantisbt/view.php?id=626 EDIT: It is you who (wyldckat) who posted the solution in the bug report. The world is a small one. |
1 Attachment(s)
There is still the error about the missing file particleTrap.H
OK, this time it stopped on this command:
wmake libso intermediate Code:
src Code:
wclean libso |
I did it the brute force way
wclean all |
